dubwarrior2
"Open up, its the filth"
Aug 22, 2019 17:46:46 GMT
Ive just removed the rear suspension arms on my VW T4. They pivot on m14x1.5 and m16x 1.5mm bolts which I'm going to replace. Ive priced them up on the brickwerks site and they are pricey. I can get them cheaper on ebay. The question is, in the description, it says to use fine thread bolts not normal pitch because "VW used fine thread for a reason"..... Really? What reason? Id have thought normal thread would be ok. They both have the same diameter. And surely part threads would be better too. Any ideas?
Aug 22, 2019 20:20:22 GMT
There would be 2 main reasons,
- you get more clamp load for a given torque with a fine pitch bolt.(it would have to be a high grade bolt as well) - too make sure the wrong part can't be used in production, typically a manufacturer will use a fine pitch for all its 10.9 grade fastners to make sure they can't get mixed up with the 8.8.
Of more importance then the thread pitch is the getting right grade of bolt.
dubwarrior2
Aug 22, 2019 20:38:29 GMT
Yeah I appreciate the importance of the tensile grade. They are torqued to 160nm.....so I'm sure a wider pitch could handle it. Either way I'll replace like for like
As kevins said, you get a lot more clamping load from the same torque, more precise clamping force too and less tendency to loosen.
slater
Club RR Member Number: 78
VW T4, why fine thread bolts?slater
@slater
Club Retro Rides Member 78
Aug 23, 2019 14:21:18 GMT
A finer thread is stronger. Think about it. The minimum diameter of a m16x2 is smaller than and M16x1.5
I'm not sure that really matters in this case tho!
Aug 23, 2019 17:19:32 GMT
luckyseven
Club RR Member Number: 45
VW T4, why fine thread bolts?luckyseven
@luckyseven
Club Retro Rides Member 45
Aug 23, 2019 19:14:37 GMT
Seems a bit overkill... you ought to be able to hang a decent-sized boat from the ceiling using even a "normal" M16 bolt and expect it to hold
Aug 23, 2019 19:25:03 GMT
well its a rear suspension arm on a 2.8 ton van, so the loads are not insignificant.
dubwarrior2
Aug 24, 2019 23:56:35 GMT
Thanks all. On anything else I probably wouldnt be overly fussed, but on the suspension I'll copy the originals. I'll also use nylocs, which VW didnt
