Painting new wingsballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Aug 13, 2019 12:12:55 GMT
Hi, I have two new front wings to fit after someone drove into me.
The wings are genuine new stock but I want to protect them before I fit them and come to get them properly painted in the future.
What product/s and process could I use on them? Rattle can some red oxide?
Thanks
Aug 13, 2019 19:04:48 GMT
If you want to go the primer route, I'd use Bonda Primer. It's not porous, so you can get away with painting it at a later date.
Aug 13, 2019 21:37:19 GMT
You can get 2k epoxy primer in a spray can. Epoxy is the only coating I would trust for storage or exposure to weather.
Either Eastwood or your local body-shop supply will have what you want. Be aware they are catalyzed, so once you start you have to use the stuff that day. Also means you spray with a charcoal respirator on your face if not fresh air make-up.
Last Edit: Aug 13, 2019 21:41:32 GMT by bjornagn
Aug 17, 2019 13:39:10 GMT
if you key it and use the epoxy then a bodyshop can paint over that /work with it , vs brush paint /red oxide will need to come off
