ive an ally inlet ion my car, and the threads for a take off have worn out. I have some tiger seal, can i use this on it to temporary fix it?
Will tiger seal go soft over time with the heat? I know i could go and buy something better, but imonly interested in heat and tiger seal.
thanks
Just helicoil it, the time you spend forking about with tigerseal, then the matter of trying to remove it again afterward - just helicoil it and do it once. It's an easy process and isnt expensive.
1994 S1 106 Rallyé 1996 Mini Cooper 1.3 MPI (Rust bucket, currently in for surgery/resto) 2003 Renaultsport Clio 172 (Daily beater)
tigerseal inletstealthstylz
@stealthstylz
Club Retro Rides Member 174
As a bodge on my own cars I usually just stick some Araldite/Epoxy on the threads and wind whatever it is in then leave it to set.
Ive run Jb weld in heads a few times, for blocking oil ways and for bridging holes in inlet ports. It holds up fine. But as mentioned, helicoil is a much better option!
tigerseal inletChasR
@chasr
Club Retro Rides Member 170
On my 2CV I was in a similar position. Sealant didn't work and as such I had a manifold that leaked.
A helicoil was about the only way I could cure it. JB weld may work in your application for a take off. Is it a takeoff you plan to use? If you do helicoil it, put locking compound around the helicoil to act as a a sealant.
Last Edit: Aug 10, 2019 8:21:51 GMT by ChasR
Aug 10, 2019 11:23:45 GMT
can get helicoil kit for next to nothing ...cheaper than getting towed home /missing work cus the inlet fell off
