MiataMark
Club RR Member Number: 29
screw threadsMiataMark
@garra
Club Retro Rides Member 29
I've bought a new seat (Sparco) for my MX5 and like an idiot forgot to buy the seat fixing bolts, as a temporary measure I thought I was bound to have some bolts hanging about. The screw spec is M8 12.9 1.25 25mm (M8 8mm thread, 12.9 high tensile, and 1.25 screw thread? 25mm long). I tried some M8 bolts I have (Screwfix) and they don't fit the thread so I'm guessing the high tensile screws use a closer thread?
I can't find a supplier open on a Saturday (unless I go to Merlin at Castle Combe).
Or am I missing something?
Ignore this , I'm an idiot the M8 bolts I have do fit (well they're too long) so will get some shorted ones from Screwfix tomorrow so I can mock up the seats while I wait for some proper high tensile bolts to arrive.
Last Edit: Aug 2, 2019 17:06:50 GMT by MiataMark
they don't need to be 12.9, a standard 8.8 would suffice (12.9 is hard to find in smaller sizes) they're still strong.
screw threadsDeleted
@Deleted
12.9 will only be available in socket head capscrew. 8.8 is the beginnings of hi tensile 10.6 is better 1.25 is standard metric M8 thread
Last Edit: Aug 2, 2019 18:07:47 GMT by Deleted
Dez
Club RR Member Number: 34
screw threadsDez
@dez
Club Retro Rides Member 34
Anything greater than 8.8 is entirely unnecessary.
MiataMark
@garra
If you need to comply with FIA regs, isn't 12.9 specified (don't have the regs to hand to check) ? Trackdays I dare say you could use aluminium.
MiataMark
@garra
If you need to comply with FIA regs, isn't 12.9 specified (don't have the regs to hand to check) ? Trackdays I dare say you could use aluminium. Aluminium sounds expensive I'm sure tie-wraps would do Although I don't need to comply with FIA regs for the sake of <£5 I'll use the proper bolts.
I almost said nylon but thought that might be a bit much :-)
i looked up the MSA blue book to double check before posting yesterday, and the only wording is min 8mm fasteners, I have been involved in building a few rally cars couple have been through logbooking process recently without issue with the seats.
harness eye bolts are specified to the letter though.
Interesting - I thought either Article 253 or FIA 8855 specified the bolts for seatmount-to-seat as 12.9 8mm min but it doesn't, I've just checked - it just says 8mm min so to the letter of the regs 8mm nylon would suffice... 8.8 8mm min are specified for mount-to-car.
slater
Club RR Member Number: 78
screw threadsslater
@slater
Club Retro Rides Member 78
Aug 12, 2019 12:07:01 GMT
I think you will find theres a more general regulation covering aluminium fasteners in there somewhere. The regs tend to do that sort of thing..
