gryphon
Club RR Member Number: 157
Aug 12, 2019 13:35:54 GMT
I realised I missed a bit from the last post - I didn't manage to get access to a lathe, but I experimented with polishing the journals anyway. I found a strap of very similar width and cut a strip of 800 grit to match it. Liberal WD40, wrapped it around the journal, wrapped the strap around that and pulled it off gently, spinning the paper around the journal. I altered my pulling angle as I went to further even the pressure around the journal. The result was pretty even but I didn't like the finish very much. I decided to leave it as it was before I do any damage. My friend who's advising me through most of this build called me a tit and to leave the finish as machined. Many different schools of thought Anyhow, the rest of the pistons went in, each big end plastigauged with the new bearings and all in spec. Next thing to check was the oil pump - there had evidently been some oil contamination, so lets have a look inside that before putting it back on. Hopefully it's good as new ones are £££! I'd never taken one appart before so was curious too. Lovely simple mechanism! The mating surfaces between the 'gears' were pockmarked but not scored, but there was some axial scoring on the sealing faces. I lightly lapped all the sealing surfaces with 800 grit to remove any high spots to reduce any future wear and put it back together... My thoughts are that it might be slightly down on pressure but perfectly useable? If you disagree shout now! Unfortunately the AJ30 block only has places to mount to the engine stand right at the top of the block - I need a sump to be able to brace it properly! I'm getting a new sump with the kit, so until I have that and can support the engine better I don't really want to add any more weight to it. I'll be picking the kit up on Saturday, so engine is on pause until then. So I cracked on with preparing the car instead. You might guess that this is far more in my comfort zone as I've not got pictures of every. single. little. step for you! First though, I picked up the new wheels - Quite the improvement I think! Unfortunately the tyres are dated '01 and totally cracked, so I need to swap them for my old ones before fitting the rest of them. I had been lead to believe the TSW wheels were very heavy... in reality it doesn't feel like there's much between them. (Anyone after a set of TSW Hockenheim alloys?? I've not got space for any more wheels!) Now it's been months since I've touched the engine bay... It was left with a mostly installed supercharger setup that ran for a single trip down the road to Caffeine and Machine and has sat there ever since. Before too long bumper and wings were off, and the engine bay was looking a bit more spacious - and in true mazda style, 5 broken bolts along the way, all into closed off sections naturally. Then it did this for a little bit... What I'd give for a decent sized garage! Once it dried off a little, engine crane came out... Then the rain came out... again...
Then the engine came out. Complete with wheels, suspension, subframe and gearbox. Very satisfying. Obviously I missed a few steps there... lots of disconnecting things, couple of little oil spills, lots of lower a few mm, check everything, lower, check etc. This gave me much better access to disassemble everything else. Each sides suspension came off as one unit: Split the subframe and steering rack off and that's most of the heavy work done... Now I have the gearbox to remove and lots more cleaning to do. I forgot to take a picture of the engine bay but it's not in bad condition under the grime... rust patches here and there to clean off, as well as on the inside wings. Fair bit of surface rust on the front end of the sills which I'm hoping is just surface rust. I need to put in a big Bilt Hamber order I think. Hydrate80 over the (cleaned) rust areas and a black underbody wax on the inner wings and lower engine bay, then patch up the upper engine bay with body colour. As much as I'd like to refresh the suspension as I go, time and money mean it's staying as it is - albeit with a bit of a clean - with the exception of the HSD coilivers going in. All the arms have been powder coated in the past, and although it's chipped and rusted in places as powdercoating does, they're perfectly serviceable. It will be interesting to see what an MX5 on polybushes drives like! I'm picking up the conversion kit on Saturday, but I got some more details on the ECU specification and am really not sure I like it all that much. Totally locked down unit, no diagnostics, no test routines or the ability to tweak things... Might not be for me. The kit doesn't even provision for any oil pressure monitoring and there is no chance I'm starting this engine for the first time without an oil pressure gauge! Thankfully Rocketeer are happy to supply the kit sans ECU and I'm looking into a more fully featured ME442 to plug in - ME already have the basemap for the rocketeer kit and beta firmware to drive the CVVT solenoids. Before I get the kit I'd really like to be in a position where the engine and the car are as ready to receive them as can be - lets hope the rain holds off this week!
Last Edit: Aug 15, 2019 9:08:28 GMT by gryphon
gryphon
Rust, Rust, Glorious Rust. But my box of Bilt Hamber goodies has arrived. I've not used them before so this is a bit of an experiment - Most people seem to rate them well but there isn't really much that I've found online about results. There are various patches of surface rust on the body but no frills (so far...). Wings are a different matter, see below! My plan with the rust proofing is clean back, possibly use Deoxy Gel but not had great results with that in the past, Hydrate 80 over rusty bits, Electrox Zinc primer over not rusty bits, epoxy mastic over the lot, then Dynax UB in high impact areas, high build primer and color where it's needed. I'll see how that goes! When I bought the car the most offensive looking bit of rust was on the front wings - both sides at the front of the wheel arch. Light bubbling that I thought could probably treat in time for it not to be a huge issues, and if not it's not like MX-5 wings are gold dust. I quickly realised that I hadn't caught it in time, I'd caught the previous owners attempts at catching it on time. The bottom of the wing where it formed a complete mud trap with the front sill was a little holey under the stonechip too... So I really need a new wing, as I have very little ability with a welder, and no access to one as the whole garage is powered via a veeery long extension lead coming out through the kitchen window that I don't think would suit a welder... everything cuts out when the mighty 25L compressor kicks in Instead I'm going to use it as practice and a test of the rust proofing. As most of the rust proofing is going to be under the car and often covered in underseal I'm not going to be keeping too close an eye on it. It will be interesting to see how long the Hydrate 80 and Epoxy mastic keeps the rust in check on a very visible wing... Then I'll get a new one! I'll take a guess/gamble at a couple of years until I see some bubbling. The grumpynortheners amongst you may want to stop reading now. I will be filling holes with filler... Got the first two coats of Hydrate 80 onto the offending areas last night. It goes on a very light blue, slowly darkens then dries to clear over 20min or so. Also gave the front of the sill a quick coat and actually remembered to get before and after pictures of it drying: I've got a lot more bits to clean and coat in Hydrate 80 before I mix a batch of the epoxy filler... In other news, gearbox needs new oil seals! Took me most of an evening with degreaser and petrol to get that sticky mess (mostly) off. And I've made a good start on drilling and tapping the snapped bolts from removing the wings. Most of them came out fine but I went off centre on a couple so a helicoil kit is on order. I've got some blingy yellow zinc passivated bolts to replace all the old ones - not sure if the red and gold is going to be a little over the top though P.S. My pictures seem temperamental due to access permissions. They always work for me and don't always work for others, so could you let me know if they disappear please?
Last Edit: Aug 15, 2019 9:10:59 GMT by gryphon
Aug 15, 2019 10:09:01 GMT
I found on ours that the wing bolts seemed to be made of cheese and snapped ever so easily, I replaced them with stainless bolts.
one of our Wings also went is the same place at the front, I welded in a repair piece.
MiataMark
Club RR Member Number: 29
Aug 15, 2019 10:24:11 GMT
I took the easy route and fitted new wings... bought at a discount from Moss. One was dented from an encounter with a robust cone at Castle Combe anyway.
Do you have any plans for the old engine, or bits of it?
gryphon
Aug 15, 2019 10:33:17 GMT
I found on ours that the wing bolts seemed to be made of cheese and snapped ever so easily, I replaced them with stainless bolts. one of our Wings also went is the same place at the front, I welded in a repair piece. They did snap easily, I was being as delicate as I could with a little 1/4" ratchet and penetrating oil too! I need to weld in a repair piece - or find some better wings. I'm being berated by mates for my planned bodgery, but on this wing at least I really do want to see how long the Bilt Hmaber stuff holds the rust back for - everybody has different answers and I want to try for myslef I haven't cleaned up the other side yet, but if it's similarly frilly I might have to enlist some help and do that one properly. Either that or I'll convert the rust with electrolysis and use the same BH products on it as a further comparison. Quite aware I'm going to be putting quite a lot of time into wings that aren't going to last very long though.
gryphon
Aug 15, 2019 10:41:35 GMT
I took the easy route and fitted new wings... bought at a discount from Moss. One was dented from an encounter with a robust cone at Castle Combe anyway. Do you have any plans for the old engine, or bits of it? £110 per wing at the mo from moss, same price I paid for the Jag engine! I'd rather repair (properly) in the long run if it's feasible, new is probably the sensible option though. What were the Moss ones like quality wise? It's actually a really reasonable price. No plans as such for the old engine but I don't really have space to keep it. It's only on 87k miles and the short time I had it running it sounded happy enough, but the oil in it is blacker than black and it's leaking said oil like a sieve. I'm keeping some of the ancillaries then likely selling it - were you after bits of it?
Last Edit: Aug 15, 2019 10:51:35 GMT by gryphon
Aug 15, 2019 11:45:39 GMT
Oil pump will be fine. I don't replace them very often, and usually when I do it's because of damage on the pressure relief valve rather than the gears or housing.
MiataMark
Aug 15, 2019 13:45:59 GMT
I took the easy route and fitted new wings... bought at a discount from Moss. One was dented from an encounter with a robust cone at Castle Combe anyway. Do you have any plans for the old engine, or bits of it? £110 per wing at the mo from moss, same price I paid for the Jag engine! I'd rather repair (properly) in the long run if it's feasible, new is probably the sensible option though. What were the Moss ones like quality wise? It's actually a really reasonable price. No plans as such for the old engine but I don't really have space to keep it. It's only on 87k miles and the short time I had it running it sounded happy enough, but the oil in it is blacker than black and it's leaking said oil like a sieve. I'm keeping some of the ancillaries then likely selling it - were you after bits of it? Might be interested in the supercharger or bits of it. I've got a passenger front wing that might be in better condition than yours, have to retrieve it from behind the shed.
gryphon
Aug 15, 2019 14:11:45 GMT
Might be interested in the supercharger or bits of it. I've got a passenger front wing that might be in better condition than yours, have to retrieve it from behind the shed. Ah, sorry - Supercharger setup is going into my girlfriends MX-5. Mine was just a handy testbed for it as it wasn't in daily use. Throttlebody, PAS pump and alternator are going onto the V6 so I have the block/head, intake/exhaust manifolds and fuel rail to move on. Thanks for the wing offer, but I'm coming under lots of condemnation for considering filler in that wing, so might be succumbing to peer pressure and doing it right with a pair of new wings. Oil pump will be fine. I don't replace them very often, and usually when I do it's because of damage on the pressure relief valve rather than the gears or housing. Thanks! Good to hear. It didn't look bad to my eye, but it's a very untrained eye.
MiataMark
Aug 15, 2019 14:24:31 GMT
Might be interested in the supercharger or bits of it. I've got a passenger front wing that might be in better condition than yours, have to retrieve it from behind the shed. Ah, sorry - Supercharger setup is going into my girlfriends MX-5. Mine was just a handy testbed for it as it wasn't in daily use. Throttlebody, PAS pump and alternator are going onto the V6 so I have the block/head, intake/exhaust manifolds and fuel rail to move on. Thanks for the wing offer, but I'm coming under lots of condemnation for considering filler in that wing, so might be succumbing to peer pressure and doing it right with a pair of new wings. No problem.
gryphon
Aug 18, 2019 22:30:44 GMT
My Lego kit has arrived And by that I mean I had an early morning drive down to Rocketeer HQ on Saturday to pick up lots of shiny bits to bolt onto my rusty car.
I also had a test drive in their demo car for the first time - it's a very civilised power delivery and a good thrust of torque. The engine needs working more than I'd anticipated, but there was a nice little kick somewhere around 4k (VTEC YO! sorry, VVT). It worked really well for the car. It's not a bonkers combination, just felt right. The 1.8 MX5 is going to feel veeery slow next time I drive it.
Anyhow - I have pictures of pretty things:
Not carbon effect - Super light and faar stiffer than an MX5...
The aluminium flywheel is a lovely lump of metal. Aluminium adapter plate to mount the Jag engine to the MX5 gearbox (And some stainless exhaust manifolds sneaking into frame) A pair of (custom, I think) throttle bodies that I hadn't actually realised came with the kit now - people were having issues balancing the stock MX5 ones that it used previously. One pretty sand cast aluminium sump. A powdercoated subframe
And a dual exit exhaust that at first glance is just the MX5 Parts one - may well have been modified to fit the cat that's also included but I haven't unwrapped.
And finally a set of silicone hoses, and a box full of smaller bits. Fixing, sensors, brackets, throttle cable, air filters... and the cat popped in for a look too*
It really is a big lego kit. Almost as expensive as one too!! Each bag comes with it's sheet of instructions and it all bolts together (I've done some of that so far, but that's for a later post)
*Yep, the exhaust cat in bubble wrap on the right - sadly I don't have one of the fluffy/clawy/feed-me-now variety.
The bit missing in all those pictures is the ECU and wiring harness, which is because I'm very torn over which to get. Rocketeer now offer an MBE unit which by all accounts is very good and just works, plug and play. No Tuning required... The downside is you can't talk to it at all. No sensor readings, no diagnostic info... just a black box. (Unless you buy MBE's specific expensive cable of course) It also comes with a very well built wiring harness which I really liked the look of. The other option is a Motorsport Electronics ME442... These are what the Rocketeer kit initially came with an people have had trouble getting them working properly, even after being tuned by ME's sister company. I'd also have to create my own loom, add some electronics in order to drive the electric water pump properly, add a second Lambda sensor controller so I could monitor each bank individually (they have separate TB's after all). And to cap it off it would be significantly more expensive.
Having typed that lot up the decision is looking a bit of a no brainer... I really want something I can plug a laptop into and play with though! Damn my need to fiddle.
The weekends engine/car progress is going to have to be a later post I think
Last Edit: Aug 18, 2019 22:56:18 GMT by gryphon
Samage
Aug 18, 2019 23:03:15 GMT
Ooh blimey... methinks you're going to be busy for the foreseeable!
gryphon
Aug 19, 2019 10:06:44 GMT
Well, I have half a hope of getting the engine in place this weekend... I've said it publicly now though to there's no chance of that happening!
Aug 19, 2019 10:49:57 GMT
Can you not use a standalone system like Emerald or even Megasquirt etc?
MiataMark
Aug 19, 2019 11:07:26 GMT
gryphon
Aug 19, 2019 12:10:40 GMT
Can you not use a standalone system like Emerald or even Megasquirt etc? I can, and from the little experience I have I quite like megasquirt. I haven't looked into Emrald so much but like the look of DTA who have the added benefit of being just down the road from me. From all options, the MBE comes out the cheapest and is far less work for me. ME already has good base maps and config files for the engine which is a bonus with them, and their tuning software looks good, but they do seem to struggle with this engine for some reason. My preference from the rest is probably Megasquirt for the familiarity and community but I need to do my research on MS and CVVT, dual lambda sensors etc, and would still need some external controllers for lambdas and water pump etc. Certainly possible, but they all come out more expensive than the MBE option, and all take a lot more work to implement as I'll have to make the harness and extra drivers etc. I'm open to recommendations though and I'll have a better look at Emerald! Thanks I have read that front to back - it's part of what convinced me to go for it!
Last Edit: Aug 19, 2019 12:14:57 GMT by gryphon
gryphon
Aug 19, 2019 14:05:45 GMT
I got home on Saturday with a boot full of goodies and cracked on with prepping the car while the weather was good. Unfortunately the next job on the list was cleaning up the inner wings, wheel arches and engine bay with the wire wheel. Not the nicest of jobs. As it turns out, when you go hunting under underseal and seam sealer for rust on an MX5.... You find rust! Who'd have thought it?! More accurately I found lots of surface rust and some patches that had been hidden under underseal. Nothing too bad so far, but I think sills are going to need some attention in the next few years. I cleaned back anywhere that even hinted there might be some rust hiding, then gave everything two coats of Hydrate 80, resulting in something a little like this: I must have used about 150ml of Hydrate 80 in total, it really stretches a long way and is really easy to apply by brush - except when you're upside down and it drips all down your hand! The next day I gave all areas a coating of Electrox primer. There seems to be a theme with BH products in that they go a long way. I'd bought one can for this car and had about a quarter of a can left from the other MX5... That quarter of a can did almost the whole job here. Covers far better than any other primers I've ever used too. Between coats I cracked on with the engine. First up, it's changed colour since my last post: I painted the front engine cover in Matt Black Enamel and it was such an improvement that I went from 'I'm not goint to paint the block' to 'what else can I paint??' Unfortunately the nice red rocker cover that had been painted in halfords finest red VHT enamel proved less than resistant to petrol, so when I gave the inside a final clean some petrol got on the painted surface and melted it. I had expected it to be more resistant.... Ah well. Now I've decided to go crinkle red for both rocker covers - the big decisions in life! Next was to start putting the sump back together. First off the sump baffle: Then the new oil pick up pipe for the new sump - long one is the new one: Then I failed entirely to get a good picture of it in place.... There was a touch between it and the baffle though which was solved through delicate use of a hammer on the baffle plate. Then back to the top of the engine and getting the heads in place... One Victor Reinz head gasket in palce. Comparing the VR ones to the OE, the main difference is where the VR has small holes to pass the oil and coolant, the OE ones has what look like nylon mesh filters. Stops larger contaminants getting into the head I guess. In hindsight I'd go with OE - as I said before! And LH head bolted on RH HG in place: And a sudden jump to all cams and timing chains in and aligned because I was too busy worrying about getting everything lined up to think about taking pictures! All my timing marks lined up and the engine spins freely but I still bolted the front cover on with a gnawing worry in my gut that it might not be right! Somehow I never get that with belts - I've always been confident that I've got it right. First time with a chain engine, and a V engine, and my gut was tying knots! The rusty old bolts holding the front cover on were really bugging me, so I've ordered a set of Yellow Zinc ones to replace them with. Not sure if it's because my first project car was the 944 which is full of yellow zinc fixings, but I do have a bit of a thing for them... On a fixings note I also replaced the crusty exhaust studs with some shiny stainless ones. Rocker covers on temporarily to keep the valvetrain clean, lower intake maifold and fuel rail also in place to free up bench space! And back to Rocketeer bits, the shiny new sump loosely in place to keep things clean again - to be torqued up once the adapter plate is bolted on to line everything up. Now I have the Rocketeer brackets to start bolting to the engine... It really is a lego kit. Here I have the parts, fixings bagged up and an instruction sheet for this step: Assemble the subassembly: (What little there is of it) And bolt it onto the engine. Et voila: Now as I stand back and think how stupidly simple they've made this, it's almost embarrassing... I realise I've put the engine mount on upside down. Oh dear. Rinse and repeat for the other side - engine mount the right way up this time! And that's about as far as I got, but the post wouldn't be complete without a little moan about... ....the weather! How dare you start raining when the BBC said it would be dry! I've got paint to cure don't you know. Thankfully it had already had about 6 hours by this point, so hopefully no harm done.
gryphon
Last few evenings seem to have been spent on cosmetics... First up, rusty fixings on the engine replaced with new ones - all the cam chain cover bolts and rocker cover bolts are now shinier: The alternator also got a tidy up. Pulley will get a lick of paint before it goes back on. The crusty engine mount buckets that I'm going to be reusing also needed a good clean up: Bit of time on them with a knotted wheel: And 24 hours in a Deoxy-C bath. I bought the Deoxy-C ages ago, then started playing with electrolysis for rust removal and never used it. Setting up the power supply and stuff again felt more effort than popping the bits in a tub of water, so I figured I'd see how it compared. Pretty well it turns out! I think the electrolysis gets deeper into built up bits where it's difficult to get with a knotted wheel, but first impressions of the Deoxy-C are good. Couple of coats of zinc over them and I finished them off with a coat epoxy mastic, no photo of that yet... Back to the engine, my new pressure transducer arrived: The original engine just had a switch, and the MX5 engine had a switch and fake oil pressure gauge in the instrument cluster that just pointed the needed to 12 o'clock whenever there was oil pressure.. I wanted something a little better than that! This is a 5V 0-100 PSI unit from ebay. Actually feels surprisingly good quality, especially for the princely sum of £8. Only issue is I haven't planned how I'm going to display the readings yet - being 5v, it won't work with the majority of gauges which expect 12v. I'm probably going to chuck together an Arduino and LCD for initial readings and sort it properly later. Last nights job was to crack out the epoxy mastic and give the engine bay and wheel arches a coating. The BH mastic seems a popular product but I've not found that much info from people using it - most just say it's nice and easy to use - so even after readings the warnings on the cans I wasn't quite prepared for how nasty the stuff is. Note one - use a proper mask! I was outside with a decent breeze so a pretty good ventilation system, but I am absolutely buying a 3M mask if I need to open those cans again. Note two - It melts plastics. Such as the plastic cups I was using to mix it. I was just finishing off the nearside wheelarch however when the bottom fell out of my plastic cup and painted a patch of floor black. I was feeling pretty stupid for obviously not reading warnings on the website, or datasheets... At least thinking I must have missed something, but no. I went back and checked the website. Only warnings are the stickers in the product photograph, which I did read but obviously didn't fully comprehend. I guess some prior experience/knowledge is assumed which I definitely didn't have. Lesson learned! Despite all that, actually applying the stuff wasn't bad at all. The areas of metal where there had been surface rust were all cleaned back, degreased, 2 coats of Hydrate 80, wiped down, 2 coats of electrox zinc primer then the top coat of mastic. The areas where there was no rust were just degreased, lightly keyed, zinced and then the mastic over the top. I'll find out in time if that was sufficient to keep it stuck on! It feels a better job than the last time I did anything like this which consisted of wire wheel, cleaned, Electrox zinc primer, then waxoyl underbody rubberised stuff. As ever, the comparison will be interesting
gryphon
Aug 30, 2019 12:09:38 GMT
Well, I have half a hope of getting the engine in place this weekend... I've said it publicly now though to there's no chance of that happening! Well and truly jinxed! On Saturday evening of the bank holiday weekend I realised that the fitting kit didn't include flywheel bolts - helpfully the first place that tells you this is the slip of paper in the bag with the flywheel fixings. All dealership parts stores being closed until Tuesday there wasn't much more I could do on the engine and not much point putting it in the car. On Tuesday I checked the stealership price for flywheel bolts and they wanted £11 each for M10x25 bolts... Not a chance I'm paying that. I sourced some M10x25 10.2 fine threaded bolts that looked right - only to find that the crank isn't a standard metric fine thread. In the end I ordered some flywheel bolts from Moss at £3 each and am still waiting on them to arrive. That's not to say I didn't get anything done though... First job on the engine was to get the crank pulley adapter in place. This mounts the old MX5 crank pulley onto the jag crankshaft. I offered it up, found that it didn't look like it would fit over the key, so got the calipers out. Crank key: 5mm wide Adapter keyway: 4.5mm wide. That's not going to fit as is then. I queried Rocketeer about it and was told that it was an interference fit and that it would go on, just start it with a hammer and wind it on with the crank bolt. I was also told that my measurements were wrong because I was using calipers not a micrometer... for 0.5mm... So, 0.5mm over 5mm is a pretty significant interference fit, but I followed their advice to see what happened. Bashed it on for about 10mm and pulled it off again: Well that looks healthy. Key is broaching it's way through the keyway. I wasn't happy to continue with that, so spent a long time with a needle file and feeler gauges widening out the keyway to approximately 4.92mm (Calipers aren't so good for that sort of resolution...) . 0.07 is still a sizeable interference fit, but doing it with a file is hardly accurate, so I didn't want to risk making it too large. This was still a very tight fit, but the key was no longer cutting the keyway so I was happier! I then had a total brainfart moment thinking that the MX5 pulley was a single piece and couldn't work out how to fit it... Oh, the central part of it hammers out! Here it is with a few coats of zinc, body colour and laquer... I've never managed to make paint stick to a crank pulley for very long, but this has had a Deoxy bath and degreasing before the primer so fingers crossed. And all fitted. Next up, gearbox. From all the sticky black gunk I cleaned out of the bellhousing, there was definitely an oil leak from either the gearbox or the rear main seal on the 1.8 engine. Most likely from both of them. New oil seal on the input shaft: Front plate off with new seal and a bead of threebond around it: And back together: There is a little play in the input shaft, which I suspect is a little more than there should be... But then apparently this box was initially designed for a rather agricultural pickup according to Bofi Racing so who knows! To fit to the jag engine the bellhousing also needs a hole cut in it to accommodate the Jaguar starter motor - accomplished with a 64mm hole saw. The paper template that I printed off didn't match up very well, so I bolted the adapter plate in place to get the location for the cut out: What a terrible picture! This put the centre point for the hole drill right on the edge of a feature, so that had to go first. The hole drill really didn't like the ally. Slow speed, steady as I could hold it. Still caught regularly but got there in the end. Bit of work with a file (suspect I'll get a fox picture if I use the full name?) and a hacksaw later had a far smoother looking hole - and a ~2mm chamfer around the edge which may-or-may-not still be required to ensure clearance to the toothed ring on the flywheel. With gearbox all prepped, adapter plate onto the back of the engine which meant taking it back off the engine stand... (and more high quality photography) The adapter plate bolts onto the block and the sump, which had been left loose to allow it to move still. Turned into a bit of a rigmarole getting it all to bolt up without holding the sump too low to make a seal. In truth I'm still not convinced it has and I'm planning to take it off again and add some sealant to the sump gasket to sump interface just in case. Without the flywheel bolts there was little more I could do to the back of the engine, so did a trial fit of the alternator: Only to find that the pulleys were decently out of alignment The alternator bolts onto the RHS engine mount bracket. When I fitted this the bolts holes didn't quite align, which I fixed with a few taps from a heavy hammer - unfortunately I didn't really think that through because in doing that, I twisted the alternator mount. A little leverage with a breaker bar brought it back into what looks like decent alignment, but I'll be keeping an eye on the belt! Enough engine for a bit... The Rocketeer fitting instructions go for mounting the engine and gearbox assembly to the subframe, wheeling it under the car, then lifting it into place to refit. When I went down to pick up the kit I was advised that with their turnkey builds they'd found that it was easier to fit the subframe then drop the engine in from the top - so I'm going to try it that way. I'll give it a shot with the bonnet in place but suspect I'll have to remove it. First step of that is to get the subframe in place. A lot of people doing the conversion have found that they need to slot a hole or two to mate the subframe to the body, but thankfully mine bolted straight up. Another bit of advice I had when I went to pick up kit was that if the subframe didn't fit it's more likely the body of the car that's moved a little and to try to use ratchet straps to pull them together rather than slotting the subframe holes. The rocketeer instructions are quite out of sync with the advice they give so I thought I'd mention it for anyone else doing this! (Think I forgot to mention, the wheelarches have had two coats of Dynax UB wax for added stonechip protection over the epoxy mastic) And now to add the steering rack... As I understand it a large part of the reason for subframe in first being easier is to couple the steering rack to the column with easy access and without having to line up the whole engine and gearbox to do so. I get the impression that the steering rack might not be removeable with the engine in place. The subframe itself is really well made, however does have some water traps. The main front crossmember is a fully closed off square section, but has holes to mount either a LHD or RHD steering rack - giving a very nice entry point for water and no exit points. The round triangulation tubes at each side also have open tops and closed off bottoms. I'm in two minds between spoiling the powdercoated finish, and adding some little drain holes. Now I'm still waiting on those flywheel bolts! gah.
Aug 30, 2019 14:21:53 GMT
Hope the engine goes well - just a quick thought - did you have the rocker covers sand blasted before painting them? If so, and they've got riveted internal baffles make sure you drill the rivets and remove and clean inside then refit. See more "tuned" engines killed by sand from blasting the rocker covers going back into the engine from the breather system than proper blow ups.
