Updates
9000
Not much to update over the last few weeks, the wheels rather fell off my wagon. Quite literally in fact
And I wasn't carrying that thing down the garden, around the house and to the driveway in the front. I'm sure I could have contacted Clarke's spares department and ordered new wheels, but what's the point when they're judt going to be a bit cheap and rubbish again. I figured I could do better for not too much more.
First a 16mm x 460mm sack truck axle. This was helpfully adressed to number 11, not number 1, and as number 11 had just moved out it is the reason I had to delay progress for so long. Eventually I managed to get my hands on it, and some 10" pneumatic wheels to suit, an increase of 2" but I thought much better suited to carting over a garden that, thanks to the dogs, somewhat resembles the Somme. Along with some nylon washers and spacers drilled to suit the taper pins, we were in business again.
Much easier to drag it around now too.
With that finally done, and with a bit of encouragement from some very, very nice 9000s at the Weekender yesterday, I snuck in a few hours to try to gain some ground on mine. One thing I had managed to to during the wait for the axle was shrink/stretch/hammer a patch into roughly the right shape for the spring perch. (Modelled against my old grey 9k which is just outside of the garage)
It wasn't quite as nice a fit on the black car but close enough to work with. Cut down to size and blobbed in
The on to the lower section. Started with an oversized section again and cut it down rather than be too clever. It worked reasonably well but I still need to refine my panel making to get the gaps more consistent. I found this difficult due to the countours on these patches. Blobbed in again, dressed off and a coat of epoxy front and back to protect it for now.
One side done.
Meanwhile I received a sizeable order from Bill at Saabits with all the suspension bushes in among other things, so when I get 30 minutes I can check those off, get the old off and send the components off for blasting. I do need to work out this little issue though as it's clearly not the right bush.
Hopefully a bit more to come soon.
T25
No new pictures from the bodyshop but the windscreen surround has been welded up, some chopping and repairs to the fibreglass top and similar treatment should now have happened to the rear corners of the gutter/top. Then I should only be prep and spray booth to go. Meanwhile I did a bit of cleaning and rewiring on the fridge to test the functions.
All very dirty, corroded and broken
cleaned and wiring remade
Happy to say the temperature when connected to mains dropped to just below freezing on max. Seems to be OK on 12V too (no thermostat conrtol). Just need to hook up the gas to esnure full functionality then it'll get a more complete refurbishment.
MX5
Should have taken the advantage of the lull in welding to swap the driveshaft...but didn't. I have (mostly) refurbished the PIAA driving lights as I just wanted them out of the garage. I still have a troublesome thread I tried to repair with JB Weld but otherwise the outcome was ok. Fitted them up and all working nicely.
Remembered I'd missed something small in the reassembly so quickly corrected that the next day only to find they wouldn't work... A bit of poking with the multimeter pointed towards the relay box, but the relay was clicking. Suspect dry solder joint. Annoyingly the PCB was drowned in potting compound which made it a nightmare to get out and scrape off
But once that was done and the joint repaired all was well again.
(Now back off because I'm not happy with how secure the lenses are, and really don't want to lose them on the move. Headlight sealant ordered)
9000
One side done.
T25
MX5
