Sept 8, 2020 12:15:16 GMT
Change of plan and have gone with a new cooper S 7.5" brake set up rather than my "big brake" 7.9" vented. This came about as I spotted a very good deal on the speedwell replicas with new tyres. Knowing full well they won't fit over the big brakes, I costed up the cooper S bits. Prices much cheaper compared to 15-20 years ago. Bought the wheels as it meant I wouldn't have to fit wide arches to cover the 6x10 100+ minilights as the speedwells are dinky 4.5x10. Keeping the other rims plus the big brake kit for another project. Plus the big brake are rather overkill for this Marcos as I've decided not to turbo it. The problem here is I'm running metro hubs so a cooper s brake set up isn't a straight bolt on. New cv joint and boots plus the driveshaft had been Powdercoated too.
jamesd1972
Club RR Member Number: 40
1979 Mini Marcosjamesd1972
@jamesd1972
Club Retro Rides Member 40
Sept 8, 2020 14:07:49 GMT
Those wheels are going to luck the business, nice. James
Sept 8, 2020 14:31:14 GMT
CV joint torque used was 193lbs as the CV's had a single split pin hole. Double hole joints use a higher load. Also joints were torqued up to full load using the washer under the nut. Then gently backed off to take the washer off. Then retorqued back to 193.
Sept 14, 2020 20:33:58 GMT
Sept 15, 2020 13:11:23 GMT
quite a specific science to the CV joint, imagine the uproar if it was only done up to 192lbs!
Sept 21, 2020 6:42:02 GMT
Sept 21, 2020 6:45:07 GMT
jamesd1972
@jamesd1972
Sept 21, 2020 6:49:13 GMT
Moving onto the inside ? James
Sept 21, 2020 14:32:54 GMT
Moving onto the inside ? James Yes and no....prep to allow the steering column to be fitted. This is a MK3 column but I think the ignition switch will be coming off and I'll use a dash mounted MK1 style ignition key/switch. Then I can fit a mk2)early MK3 column shroud for the cleaner look. Also there will be some steel bracing going into the dash to connect the column drop bracket to the pedal box.
Sept 25, 2020 9:27:28 GMT
I'm after a shabby mk4 mini steering column. Doesn't need electrics or steering lock/ignition switch housing.
Sept 28, 2020 16:56:04 GMT
frodo
Sept 29, 2020 8:27:20 GMT
I rarely post on here but wanted to say top work - this looks really good and I’m learning a lot about how good you can make fibreglass look which should help on my build (Scimitar race car with a Chevy LS). Thanks!
Didn´t look at this thread for ages and now i´m sorry. An excellent repair job on some real dogs dinner work by the previous owner. Glad you´re going for the Jem front. Much better looking I think.
This is a brave and extremely cool project. I had the dark red Corgi Toy.
John
Oct 10, 2020 15:47:00 GMT
A few hours this afternoon cutting the other down tube.
Oct 13, 2020 17:14:18 GMT
Rear frame tacked up so waiting for intergalactic to come back to me to get it tigged.
Oct 13, 2020 18:16:12 GMT
Tig will be still create too much heat. I hope you are taking it out to weld!
Last Edit: Oct 13, 2020 18:16:36 GMT by miniswift
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
Oct 13, 2020 20:10:16 GMT
Tig will be still create too much heat. I hope you are taking it out to weld! Obviously
jamesd1972
@jamesd1972
Powder coat while out ? Green or black though. Coming together nicely. James
