As I'm waiting on some parts arriving with the Invacar, today I turned my attention to the van. Today's target was the hob - not least because I'm sick of tripping over it.
It did need a good clean though before I was going to handle it any more than I had to. The whole thing was sticky and just generally horrible.
Yes, I do have the missing knob, it's missing the spring clip which holds it on though so I've just left it in the box of random van parts for now.
After a good old scrub though it was looking much more presentable.
I've moved the missing knob to the grill position as I've yet to build the box below for it to sit in. Though being honest I'm less bothered about that as it's not something we're really likely to use often.
After a bit of carpentry it was in place.
I've got a couple of metal plates which I'll install underneath as a heat shield. Plus I've insulated everything even vaguely near to it with aluminium foil tape as well.
No it's not perfectly straight...but neither is the whole worktop relative to the wall of the van. This whole worktop will be coming out and being rebuilt at some point in the future as it's an utterly unsuitable material for use in a van and really isn't fitted well (it does slope back towards the offside wall as much as it looks like it does in the photo).
The fact that the kitchen layout has been completely changed is obvious by virtue of the cover opening the "wrong" way. Obviously the hob originally would have been recessed as well so this would have been flush with the rest of the work surface when closed.
Initially I thought that the hob might have originally been where the sink now is - but if that was the case the grill would have been totally inaccessible. Hmm.
We'll figure out things like that somewhere down the road though - for now it can live where it is, it's ugly but having a working hob will be worth that when we're using the van. Just having it functional again will be good enough for me for now. Should have it up and running tomorrow, just need to hook it back up at the manifold end and obviously leak check etc. Just ran out of daylight today.
