Got the new lights in the van a proper after dark test run.
Up until these arrived I had never actually seen phosphor yellow/amber LEDs in person so it was an interesting technological experiment in itself.
The colour definitely brings to mind old school low pressure sodium (SOX) lamps albeit with surprisingly good colour rendering for an amber light.
I've finally gone around most of the shelves, drawers and lockers with the non slip matting.
This will hopefully do a bit to cut down on the clonks and rattles. It's definitely helped as it's noticeable how much less drumming there is just opening and closing the doors.
The inverter has now been mostly hooked up. The control panel and socket are now in place (note the red socket face to help highlight it's its own thing rather than part of the wider AC system).
Bit irked I fouled up the alignment so the socket sits a bit too high.
The green DC on light was bugging me too. I'd hoped to be able to get it to fit better.
Knowing I had a spare one of the mains indicators floating around I decided to pull that to bits and convert it for 12V DC use.
Surprising how many bits is inside a simple mains indicator!
I had a play around with a few LED options but couldn't find one that really gave a usable spread of light, so opted for a small incandescent lamp instead.
In place...
Then reassembled and tested out.
I'll get that dropped in tomorrow hopefully. The only other inverter task I've got to do is to actually hook up the supply leads in the main vehicle battery box which should see that up and running. Oh, and get some labelled printed off so it's clear what it is.
In place...
