Jan 13, 2019 19:59:21 GMT
Very nice repairs, almost invisibel. I am surprised about the amount of effort and time you put into this car and not knowing if you will keep it. Keep up the good work and its fun too watch Peter
Jan 14, 2019 10:18:00 GMT
Very nice repairs, almost invisibel. I am surprised about the amount of effort and time you put into this car and not knowing if you will keep it. Keep up the good work and its fun too watch Peter If I had the space I would keep everycar I ever owned!
jamesd1972
Club RR Member Number: 40
Jan 14, 2019 13:29:09 GMT
Very nice repairs, almost invisibel. I am surprised about the amount of effort and time you put into this car and not knowing if you will keep it. Keep up the good work and its fun too watch Peter If I had the space* I would keep everycar I ever owned! *and money ? James
Jan 14, 2019 13:34:40 GMT
If I had the space* I would keep everycar I ever owned! *and money ? James Pretty much all of my cars have been under £1000
Jan 14, 2019 13:36:16 GMT
Great Videos Jim.
Keep them coming your fabrication explanations are great to watch you must have been chatting with Grumpynorthaner.
Last Edit: Jan 14, 2019 13:36:30 GMT by peteh1969
Jan 14, 2019 14:18:43 GMT
The work is brilliant but I have to say - I'm v v impressed with the fact that you're doing this in a car park. I'd literally lose the will to live doing that (because I wouldn't just forget to pack a tool I'd subsequently need, in the car prior to travelling but do it 5 or 6 times......).
if I wore a hat i'd doff it.
Love the car too.
Jan 14, 2019 15:02:40 GMT
I see you post on you tube with the name Nitrosilvia. Is that your editing assistant? And if she desrves her name, i think we need to see a picture of her......
I see you post on you tube with the name Nitrosilvia. Is that your editing assistant? And if she desrves her name, i think we need to see a picture of her...... I'm afraid its just me. The name came from my Nissan Silvia track car.
Done a couple of bits that last two evenings.
I stripped done the front, got the bumper irons off, and the oil cooler, ready for me to treat the surface rust. ALso straightened the nearside tow eye.
Then i started making a replacement panel for the bottom of the nearside wheel well. I offered up a new belly panel and used card to make a crude template. Then offered it up to the offside to check the fit.
I made the new panel out of Zintec steel sheet and started to shape it. Ill do the rest of the shaping when I come to weld it in.
Jan 16, 2019 22:04:27 GMT
jules
Jan 16, 2019 22:32:36 GMT
Amazing work, even more so that your doing it in a car park, in the dark in the middle of January !! + your capturing/filming it for our entertainment. You go inside to make/shape the panel and then back out into the dark and cold to carry on, if that's not dedication then I don't know what is !
Should get a MBE for services to SD1's !
Jan 17, 2019 16:48:00 GMT
rang the breakers yard today, they are gonna check on the colour of the interior for me.
Jan 17, 2019 20:07:39 GMT
saw that on fb,cant see it being much good? hope it has some parts for you though!
Jan 21, 2019 12:38:42 GMT
Did a fair bit on Sunday. I salvaged some 0.6 mm wire from a welder not of the scrap pile to replace to 0.8 mm wire i had accidentally bought off ebay. Tacked in and then did the final shaping of my wheel well repair section. When it was mostly in i offered up the underbelly panel and formed the lower lip by bending it at 90 degrees with a pair of pliers. I finished it off with a pair of hammers to make a nice neat edge. Then i cut a square hole in a tab of the flange to take the captive thread for the underbelly panel mounting. After that i chopped off the lower corner of the outer wing and inner wing. I sectioned up a new inner wing ready for the repairs but didnt get around to actually welding it. I also had a real good poke and chop at the floor so i could start planning the repairs. Long video of all of the above.
Jan 21, 2019 15:18:50 GMT
Great explanation Video Jim with a great result.
Keep them coming.
Jan 25, 2019 22:17:25 GMT
Great progress on the latest video Jim.
Weather should be a bit better until Tuesday so you should be able to get more done.
Jan 27, 2019 12:09:57 GMT
Great progress on the latest video Jim. Weather should be a bit better until Tuesday so you should be able to get more done. Thanks Pete. Unfortunately I had other stuff to do Sunday and beginning of this week. Next weekend looks doubtful too, so I need to make more use of the nights.
Jan 27, 2019 12:24:58 GMT
jamesd1972
Jan 27, 2019 12:56:51 GMT
Great progress, is this the good or bad side ? Thanks for the updates as always James
Jan 27, 2019 13:14:01 GMT
Brilliant progress Jim, there's nothing more satisfying than rebuilding an area that was once air and rust (well other than actually driving the car) enjoying the videos of the rebuild.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
