Sammo
Club RR Member Number: 103
Nov 13, 2018 18:19:32 GMT
Follow Me On Instagram - @parttimecartinkerer
Very nice work mate, its a joy to see another being brought back to life.
Mk2 Golf 16V resto
Sammo
Nov 16, 2018 14:01:09 GMT
Soooo the Golf has just had its MOT which it passed Some advisories which I knew about anyway but pretty good considering how long it’s been sat
jmsheahan
Club RR Member Number: 121
Nov 16, 2018 14:28:40 GMT
Happy days Sammo, nice work! Great to see another brought back into use
Sammo
Nov 16, 2018 19:00:51 GMT
The advisories were; A very perished N/S outer CV gaiter - Not quite split but very close. A very perished N/S steering rack gaiter - Nearly split as well. Both wiper blades perished - Already replaces them. Both front brakes fluctuating slightly when applied - This is due to surface rust. All brake discs corroded - These should clean up with more driving. O/S/R tyre close to the legal wear limit - I’m replacing both rears on pay day. Corrosion to the bodywork on the rear - Slight bubbling around the O/S corner. All in all these advisories are nothing. I’ve ordered a new CV gaiter which I’ll replace over the weekend and then start driving the car to clean the brakes up etc. Annoyingly, but not surprisingly the aftermarket GTi arch trims I bought don’t even come close to fitting so I’ve just ordered a set of used genuine VW arch trims in good condition. Here’s a picture of the car in the workshop this morning having a track rod end freed off before the tracking was done
tristanh
Routinely bewildered
The arches weren't from Werk34 by any chance?
Sammo
The arches weren't from Werk34 by any chance? The aftermarket ones or the used ones??
broady
East Midlands
Nov 17, 2018 11:00:33 GMT
Just had a nice little read, a pleasing project, enough to do to make it interesting but not one that dragged on and on! Good work
Sammo
Nov 17, 2018 12:53:26 GMT
Just had a nice little read, a pleasing project, enough to do to make it interesting but not one that dragged on and on! Good work If you fancy reading something that drags on and on then head over to my V5 Caddy Build thread haha. That one is a proper drag!
broady
East Midlands
Nov 17, 2018 15:26:17 GMT
Haha ill pass, I'm busy writing my own never ending story, ill be at 10 years come January
tristanh
Nov 17, 2018 19:24:28 GMT
The arches weren't from Werk34 by any chance? The aftermarket ones or the used ones?? The ill fitting aftermarket ones.
Sammo
Nov 17, 2018 19:47:11 GMT
I got them from Classic VW.
Sammo
Yesterday morning I dropped my daughter to her dance class and then rushed straight to Eurocarparts to pick up a CV gaiter. Then it was a quick dash to work to get it replaced. Because I was pretty short on time I called ahead and got one of the techs to get the car on the ramp and in the air ready for when I got there. After the MOT was done on Friday one of the techs had asked if he could take the Golf for a drive. I told him to crack on and carried on with my work. He obviously took it for a spirited drive because the rather perished CV gaiter that had been advised on the MOT was now destroyed :laugh: Anyway, off came the driveshaft and into the vice. The CV joint came off nice and easily which makes a change, I cleaned everything up and then got the new gaiter on. And then the joint when back on At this point I suddenly realised it was almost time to go and pick my Daughter up so I stopped taking pictures and just got on with getting the shaft fitted. It’s all back together but the car has now decided it’s going to misfire! I’ve still got to service the engine, change the cambelt and clean everything out so hopefully I’ll find something that’s causing the misfire while I’m at it.
Sammo
Jan 26, 2019 20:37:03 GMT
A quick update for this. Due to the curse word weather I haven’t done anymore to the Golf. It’s been parked outside my house just waiting for me to do some more bits to it.
The things that need doing urgently are:
Replace the radiator which has started leaking
Replace the engine cooling fan which is dead
Replace the thermostat which I suspect is a little sticky
Service the engine
Replace the cambelt
Replace the oil pump pickup
None of these things are particularly difficult to do, it’s just having the time and the weather to do them.
Anyway, today I decided to remove the radiator so I could figure out what it’s from and have a look at where the thermostat lives. The radiator came out nice and easily and has definitely seen better days. After some searching online and eventually asking on Facebook it was identified as a Golf G60 radiator, which makes sense as this had a G60 engine fitted when my brother bought it. Annoyingly this particular radiator is stupidly expensive to buy, so I’m now looking at alternatives, however this will mean having to re-route the coolant pipes for the new one. I’ll have a think about what to do.
While I was doing that I had a look at how to remove the thermostat. To me it appears the alternator is in the way, but apparently it can be changed without moving anything except the dipstick tube! I can just see I’m going to end up rounding a bolt haha!
Well that’s the update. No pictures I’m afraid. It was freezing outside, blowing a gale and starting to rain so I just wanted to get back indoors ASAP!
tristanh
A mk2 8v rad is enough for most people, and wider than a 16v one.
Paul
Aye careful with the bolts around the thermostat flange...in my experience they're made of cheese and v easy to round.
Good work going on here. Always good to see a mk2 coming back to life.
broady
East Midlands
have a look at local radiator repair/service places. there is one near me which will repair small leaks for nice reasonable prices (less than a new rad) all will the way up to a full recore for when a replacement isn't available.
Might be worth it to keep the G60 rad on a G60 ningine
Sammo
An update with no pictures today.
Today my Daughter and I set off on a 200 mile round trip to collect a complete Mk2 Golf GTi interior in excellent condition. Luckily we set off early enough that there was no traffic at all which makes a change. Anyway, it all went without a hitch and I’ve got the whole interior sitting in the back of my 5 series saloon (that was interesting getting it all in!!)
The main point of this is actually when I got back in the BMW this evening to drop my Daughter home the smell of the interior was very apparent in the car. It amazes me how a smell can evoke a memory and the smell of that 19 year old VW interior took me right back to when I was 18 and had a Mk3 Polo G40.
All a bit pointless without pictures but it was the smell that set me off haha.
I can associate with 'car smell'. My Cavalier has 'that smell' that takes me back to my Grandads Mk1 when i was a kid. Also it's weird how 70s BL made cars have a smell of their own. (waiting for the obvious replies to that comment )
Last Edit: Feb 3, 2019 20:53:04 GMT by cavboy80
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
