I got the Bobcat Golthwait reference!....
I know the plug wires tested okay cold...but could they be acting up when running?...have you looked under the hood at night? any arcing?...
hmmm...carb or dizzy internals?
car looks great, by the way. really shines.
JP
Issue occurs cold.
Everything is suspect. Dizzy cap, points plate, wires, plugs, coil.
Phil
That makes the hard work worth it. Phil Oooooooooohhh.
Nice shine. Trust nothing in ign, replace the lot and then see. Plug leads and plugs do odd things under load that they don't do when tested statically.
Oct 20, 2019 12:55:50 GMT
That means a lot, but you haven't seen the paint up close... Phil
Oct 20, 2019 13:09:17 GMT
Nice shine. Trust nothing in ign, replace the lot and then see. Plug leads and plugs do odd things under load that they don't do when tested statically. yeah, thats what I was getting at. Thanks, blackpopracing. well said. JP
Oct 20, 2019 13:13:07 GMT
That means a lot, but you haven't seen the paint up close... Phil For a car of this generation, unless that is what you are going for, it does not have to look brand new or perfect. What we see, through our screens looks pretty darn close and looks very appropriate! JP
Oct 20, 2019 13:15:15 GMT
yeah, thats what I was getting at. Thanks, blackpopracing. well said. JP Everything is suspect. Dizzy cap, points plate, wires, plugs, coil. Phil I know, accountant says dull things like electric bill and car insurance gotta come first though.
Last Edit: Oct 20, 2019 13:15:40 GMT by PhilA
Oct 20, 2019 13:43:25 GMT
Oct 20, 2019 14:12:58 GMT
Ooh, '52. Comes with fancy things like Dual-Range Hydra-Matic and uh, yeah. That!
Shame they have a mishmash of dial pulls but that is a really nice six.
Phil
Oct 20, 2019 14:31:12 GMT
It was very nice condition, you have nicer hubcaps and bonnet mascot though.
Oct 20, 2019 14:38:34 GMT
Well, things like hubcaps got changed up annually because changing the stamping for that is much cheaper than the tooling for the body.
GM were trying to milk every penny in '52 because of the Korean war and the steelworker strike. If you knocked your knuckles on the fenders of that one and then the same on a '53 you'd hear the difference. '53 the steel was a lot thinner, that one is more like an original Moggy Minor- clonk clonk to knock against.
The illuminated mascot was an option, also.
It's nice at that age (<1/9/1965) they don't have to screw with the wiring and pfaff about to put orange indicators in.
Phil
Last Edit: Oct 20, 2019 14:49:23 GMT by PhilA
Oct 20, 2019 15:18:42 GMT
It made me think. What you think, standard straight arm truck peep mirrors or angle arm peeps?
I need to replace mine before inspection because one is cracked and all the silver's gone, and the other I cannot see anything out of because it won't adjust far enough.
Phil
Oct 20, 2019 15:35:31 GMT
angled...far classier.
Oct 20, 2019 17:20:32 GMT
That's kinda the direction I was thinking of going, keeps the mirror in line with the line of the windshield visor.
Phil
Oct 20, 2019 20:23:47 GMT
Angled.
remmoc
Oct 20, 2019 21:18:22 GMT
Oct 20, 2019 21:30:11 GMT
Yeah, I was thinking of various ways to sort it out, one method would be to drill it out, tap a thread in the hole and drill a bolt through it's center to the correct size and screw it in.
Then at least, like a bushing, it would be replaceable. Space is at a premium on the one that's gone sloppy.
Phil
Last Edit: Oct 20, 2019 21:31:47 GMT by PhilA
Oct 21, 2019 13:04:44 GMT
Oct 21, 2019 14:29:26 GMT
The paint looks great for its age! how does the modern fuel affect the running or can you guys still get leaded stuff?
