Jul 20, 2019 18:37:49 GMT
Are you going to use door seals or something to make it a bit more air and water tight? You'll still get water driven inside if it's a bit windy.. Good solution, though! I´ve made it so that the original sliding door seal from VW should work, well that´s the cunning plan Fantastic work. I'm liking the stealth camper look too. ...stealth camper, i like that Fred, as long as i don´t have to paint it matt black to match the name though... ...much appreciated mate! Probably too late now, but if you use a compressor fridge, you don't need the vent in the side of the van, plus they use way less power than a 3 way. You could do away with the leccy hook up point below the filler by having the hook up via a short trailing lead through one of the rear fog light apertures, they come out easily an there is plenty of space behind them for the lead when it's not in use. Just sold my T4 and going bigger with MWB Crafter. You´re right about the fridge mate, however the 3 way ones do have one or two advantages. They´re cheap and readily available, mine came with the second hand kitchen i bought. My experience with the old three way fridges is that once you´ve got them up and runing on gas you´re laughing, they cool better and it doesn´t matter where you are....oh and did i mention they don´t cost much either Alot of people put the electric socket behind one of the rear foglights in the bumper. Not a bad idea mate but i´ve just spent ages moving the hole from the side to under the filler neck so i´won´t be moving it again. I needed a break from sanding so i thought i´d attack the rust in the front left hand corner behind the wing.... Normally the main battery and all the wiring are hidden away in here... I´ve seen worse (or should i say i´ve driven worse) but it still needed a bit of attention...so i chopped out all the rust... and let in some 1,5mm plate with the repairsection welded in i cleaned it all up a bit and gave it all a couple of coats of Ferpox epoxy primer and to finish it all off, a coat of "Schutz" to help stop the rust coming back... That´ll do me.... ...a good days work, much better than sanding filler. Cheers, Dave
Feb 24, 2020 11:30:34 GMT
What happened to this fantastic build?
urbanaw
Club RR Member Number: 17
Feb 24, 2020 16:25:43 GMT
This thread proved to be so much better than I expected!
trimtechniques
Porsche 928 4.7 ltrs of German grunt. Mazda MX-5 MK1 Dakar. VW T4 camper
Mar 21, 2020 23:18:51 GMT
What an epic build. I can't wait to see it finished to see how much extra space you will have created.
What happened to this fantastic build? Cheers, the build is still happening. Our internet at home is a night mare and i just haven´t found the time to upload the pics and update my thread. This thread proved to be so much better than I expected! Thanks for that mate, What an epic build. I can't wait to see it finished to see how much extra space you will have created. Cheers mate, much appreciated. Spacewise the conversion will help a bit but it´s still going to be a bit cramped up in there. Time for a litte update. I have been putting in the hours but i don´t have that many photos to show for it. As the last update was in summer i´ll show you what i got up to last autumn. With the days become shorter and the temperatures starting to drop i thought i´d try to get some paint on the van before it got too cold. Now there was no way i was going to get all the bodywork ready for paint so i thought i´d try to respay a bit at a time. It´ll mean a lot more masking than normal and to be honest although i´ve done one or two resprays in my time i´ve never done one an bit at a time. As all the welding on the right hand side was finished it seemed like a good place to start so after weeks of sanding and filling (i´ll spare you the details) i cleaned up the garage, gave the floor a once over with the garden hose and gave it a couple of coats of filler primer.. After another couple of weeks of sanding (god these long and high T4´s are no comparision to sanding down Merc 123´s or Capris) I knocked up a provisional spraying booth, got the gas heater going full blast, took a deep breath and gave the side a few coats of Tornado red Hope you like it, i´m chuffed with the result. As i mentioned earlier there was no way i was going to get the other side done before it got too cold and to be honest i needed a break from sanding anyway so i thought i´d get some work done on the interior. I´d done most of the hard work but i managed to get hold of a load of aluminium profile.l.. so i´ve ripped out the rear slide out as it was way too heavy and have come with a better way of extending the bed out of the rear, but more of those antics in the next update. I can say i´ve been at it all winter and i´m still not finished. Cheers, Dave
Last Edit: Apr 4, 2020 17:45:29 GMT by Oldbus
Glad to see this is still going. Nice half spray booth
With a little forward planning & preparation it is amazing what results with paintwork you can achieve in a small restrictive area with the minimum of equipment - just sheeting off the van like you have done in the pics saves overspray landing everywhere and dust migrating from elsewhere and embedding itself in the wet paint - Visitors to my own small workshop are always impressed that I produce high quality professional paint finishes without the requirement for a large heated spray booth & lots of very expensive equipment - it takes me longer but the with right mindset and some diligence expended at the preparation stage tends to produce good results - Oldbus - credit to you - it looks great PS - You are on the right track with the masking but have you come across 'Polymask' - available in 4m / 5m / 6m wide rolls readily via e bay or your local automotive paint factors - will save you a lot of effort with masking / protecting freshly painted panels etc - especially on a van of that size - example below www.ebay.co.uk/itm/Masking-Film-Roll-Static-Polymask-Over-Spray-Protection-4M-5M-or-6M-/202355387002Good look with the rest of the work - Chris
urbanaw
Tornado red - the best colour in the calssic VWs range. Looking forward to the updates.
Great result!. Glad that you are continuing with this build... Thoroughly enjoyed the inventiveness and thought processes for the slideouts.
npp
Tornado red - the best colour in the calssic VWs range. Looking forward to the updates. the only car I ever bought new (so the one time I had a choice of colour) was a MkV Golf in Tornado Red - base spec but 2.0 TDI and sports suspension
Glad to see this is still going. Nice half spray booth Cheers, half spray booth It took me longer to clean up the garage than it did to make up the "spray booth" but it made a hell of a difference keeping the dust at bay and as Mr Grumpynorthener says i don´t like overspray either. With a little forward planning & preparation it is amazing what results with paintwork you can achieve in a small restrictive area with the minimum of equipment - just sheeting off the van like you have done in the pics saves overspray landing everywhere and dust migrating from elsewhere and embedding itself in the wet paint - Visitors to my own small workshop are always impressed that I produce high quality professional paint finishes without the requirement for a large heated spray booth & lots of very expensive equipment - it takes me longer but the with right mindset and some diligence expended at the preparation stage tends to produce good results - Oldbus - credit to you - it looks great PS - You are on the right track with the masking but have you come across 'Polymask' - available in 4m / 5m / 6m wide rolls readily via e bay or your local automotive paint factors - will save you a lot of effort with masking / protecting freshly painted panels etc - especially on a van of that size - example below www.ebay.co.uk/itm/Masking-Film-Roll-Static-Polymask-Over-Spray-Protection-4M-5M-or-6M-/202355387002Good look with the rest of the work - Chris Thanks for that Chris, i´ll bear that in mind when i get round to painting the rest in summer. On the subject of minimum equipment and lots of elbow grease. I definately agree with you there mate, although to be honest the quality you knock out is amazing, i´m nowhere near your level of skills when it gets down to spraying but over the years with trial and error or should i say more error than trial, the results do get better. Just don´t tell anyone how long it takes to get a decent finish and always buy decent paint. Tornado red - the best colour in the calssic VWs range. Looking forward to the updates. Tornado red was my third choice, if i´d have had free choice i´d have gone for Atlantis blue or a dark silver but as thy´re both metallic there´s no way i´d be able to get a decent finish with a garage DIY spray job...so Tornado red it is. Great result!. Glad that you are continuing with this build... Thoroughly enjoyed the inventiveness and thought processes for the slideouts. You´ll enjoy the new rear slide out then Dave, hundreds of anglegrinder discs and loads of trial and error Tornado red - the best colour in the calssic VWs range. Looking forward to the updates. the only car I ever bought new (so the one time I had a choice of colour) was a MkV Golf in Tornado Red - base spec but 2.0 TDI and sports suspension You´re right mate, it´s not exactly a rare colour but it´ll do me!
Talking about Tornado red, i did manage to get a bit done before the winter set in. I´d already done the tailgate but unfortunately it fell off the paintstand and not only wrecked the fresh paint job but got so bady dented that i had to get another one....so much for tial and error Like i said, i chose Tornado red as it´s DIYable and on a normal T4 with a short wheelbase and without the high roof it looks good, but mine has the long wheelbase and high roof and with only one colour it´s a bit too much so i got some dark grey and copied VW´s two tone paint job that was available for the earlier T4´s Once i´ve got the other side and roof done i´ll flatten it all back and clear coat it all. The roof will be getting some red red and grey too, not sure what you guys think but it definately works for me. Cheers, Dave
I think it looks great and such an amazing transformation and is one of my favourite builds on here 😎 is it too early to be discussing wheels?
Dave - It does not matter what we think - you do it the colour scheme that pleases you - its your van / bus after all - having said that I like anything that makes it's statement in a retro calm & calculated manner (and this will) - it does not have to be full of bling or be just ordinary to stand out from the crowd
Last Edit: Apr 7, 2020 20:42:19 GMT by Deleted
I like the pinstripe detail. Looks good! It looks like you haven't greyed out behind the panel gaps, yet? At least on the rear of the door. Which I guess is because you haven't unmasked the van to open the door!
That grey really makes a difference. There was a LOT of red before.
Nice work!
Ive been thinking about this project on and off for a while now and am very glad we are hearing from you again...the van looks great. I really like the two tone detail...glad you took the extra time to make it happen.
looking forward to more updates.
JP
Apr 11, 2020 13:16:59 GMT
love this build and thread, proper oldbus fabrication.
Apr 12, 2020 18:03:20 GMT
I think it looks great and such an amazing transformation and is one of my favourite builds on here 😎 is it too early to be discussing wheels? Cheers mate and it´s never too early to discuss wheels I bought these ages ago and for the first time in my life had them professionally refurbished. Not cheap but well worth it, they´re Projekt Zwo 8,5x17-s for the front and 10x17´s for the rear. Defintely one of my favourites for the T4. Dave - It does not matter what we think - you do it the colour scheme that pleases you - its your van / bus after all - having said that I like anything that makes it's statement in a retro calm & calculated manner (and this will) - it does not have to be full of bling or be just ordinary to stand out from the crowd You´re right Chris, i was just being polite I like the pinstripe detail. Looks good! It looks like you haven't greyed out behind the panel gaps, yet? At least on the rear of the door. Which I guess is because you haven't unmasked the van to open the door! Well actually i did make the effort and masked off part of the sill and B Post when i sprayed the door. I didn´t want too much grey on the inside but underestimated how much grey i needed so that you coan´t see any more red with the door closed. Next time i´ve got grey in the spraygun i´ll have to widen it a bit methinks. That grey really makes a difference. There was a LOT of red before. Nice work! Cheers George, i really was surprised how good it turned out as i had to take a guess on the right colour, and you´re right mate it was too much red especially as i haven´t painted the roof yet. Ive been thinking about this project on and off for a while now and am very glad we are hearing from you again...the van looks great. I really like the two tone detail...glad you took the extra time to make it happen. looking forward to more updates. JP Thanks JP, hope everything is ok the other side of the pond. love this build and thread, proper oldbus fabrication. Thanks, lots of error and a bit of trial (in that order) Updatewise i´m still cathcing up.... With a very cheap supply of aluminium profile available i took a deep breath, had a couple of beers and decided to bin the rear slide out. I know it was a lot of work but the main reason i wasn´t happy with it was that you could hardly put anything in the boot and i´d have ended up with fairly large van and having to throw everything on the bed when we went anywhwere, so i got the anglegrinder warmed out and chopped it all out. I then insulated the now empty floor, cut some of the ally profile to length amd filled it with construction foam. Horrible stuff but it should help keep the warmth in a bit. The sides and floor have been double insulated with a bit of this stuff... " alt=" "] and some of this... and when i get round to finishing the roof i´ll try to get that stuff in there too. My son Christian sold his Sierra the other month and bought himself a 92 Multivan (guessed who influenced his decision a bit ) i had to tidy up the garage to get it in but it did make agreat pic. Cheers, Dave
Last Edit: Apr 12, 2020 18:08:05 GMT by Oldbus
Apr 12, 2020 18:58:00 GMT
Perfect wheel choice 😎 they really work with T4. Nice to see another one in the garage 👍
