Sept 25, 2007 20:04:19 GMT
Sept 25, 2007 20:22:42 GMT
;D check out the ducting on the underside
Last Edit: Sept 25, 2007 20:24:28 GMT by samyboy
Sept 25, 2007 20:24:54 GMT
didnt someone on here put a 1.8 into a metro
gotta be failry simple at the blocks are all the same innit?
2001 HONDA CT110 (NOT RCV)
Sept 25, 2007 20:41:15 GMT
do they come in beige?
Sept 25, 2007 20:42:28 GMT
would they look right mit der banded?
Sept 25, 2007 20:48:58 GMT
jah,das iast sehr gut mein freunde. ;D
Sept 25, 2007 20:52:58 GMT
;D check out the ducting on the underside I was given a lift in this around Curborough sprint track a couple of weeks ago, and was mighty impressed at how well it went around the track. It seamed to have loads of front end traction and pulled really nicely out of corners. Also the talon guys are absoultly spot on They also had a mid engined metro that I went out in which was a work in progress ;D
Sept 26, 2007 9:21:32 GMT
A graphic lesson in why big manufacturers need to engage the services of smaller companies to make their cars decent
Sept 26, 2007 10:27:17 GMT
Looks like a real hoot, Rover should have done it as a step up from the GTA. Do these still have a 4 speed box? 'Twas always getting laughed at in road tests I remember
Sept 26, 2007 10:56:20 GMT
Seems a bit harsh charging extra for a stripped interior!
An 160bhp Metro has to be a laugh though.
Jaguar S-Type 3.0 SE
Sept 26, 2007 11:02:04 GMT
A graphic lesson in why big manufacturers need to engage the services of smaller companies to make their cars decent BL/rover never got the hang of that, Ford and Cosworth and Vauxhall and Lotus seemed to knock out some good gear so i dunno why they never learnt, i spose Cooper was about the best they could did? not that i'm an expert.
Sept 26, 2007 11:06:05 GMT
"Mechanical Power Subduing Animal Speed" (Robert Trevithick, 1808)
'72 BMW 2000 Touring '99 TT 180 (mrs) '72 BMW 2500
