Ritchie
Club RR Member Number: 12
Subaru Brat WRX.Ritchie
@ritchie
Club Retro Rides Member 12
Hi all, I thought I'd post up some further info on the progress made. Again, apologies for the lack of pics, I really need to get my act together. After I got the front downpipe made up I carried out with the rest of the exhaust, I was pretty happy with how it turned out but was a bit concerned it might be a bit loud but time will tell.
I then went on to install the low pressure Facet fuel pump and filter under the bed and used the existing fuel lines up to the swirl pot. This was straight forward enough and seems to work fine. As you can see from the above pic in the last post, the HP pump and filter was plumbed in and everything was hooked up to a battery just to check for leaks and it all was good.
Last Edit: Mar 15, 2020 6:47:41 GMT by Ritchie
Ritchie
@ritchie
With the exhaust all wrapped and installed it was time to move on to the engine bay. I had mentioned previously about the rad porting issues I had, so I had a go at re-locating the bottom one myself with a trimmed plumbing fitting.. It looks ok but time will tell if it will hold water. This is the top fitting installed with a reducing hose. I had already managed to obtain an early legacy chargecooler, pump and rad so I made up some brackets to mount and plumbed it all in. The rad was a tight squeeze behind the grill but with some grinder action on the back of the grill it will fit ok. 2x 10" fans were installed on the main rad behind it, again not a lot of room. Next it was onto the battery and air filter arrangement. Obviously there was no room for the original air box so I took some measurements and had a dig around the battery shelf in my local motor factors to see if I could find a smaller battery with as close to the original required cranking amps as possible. Luckily I fnound one and even managed to use the original battery clamp with the new battery rotated 90 degrees allowing room (just) for the aftermarket filter. I know that some say that these could possibly cause issues with the MAF over time but I don't really have a choice. please excuse the dodgy wiring, this was just hooked up as I will get to. Fluids were replenished and it was time to tackle the wiring. I already had a loom made up from the original WRX loom, and it worked very well. hooked it all up and it fired up first turn of the key, with no leaks and the power steering is working perfectly which I'm very happy with. So, I still have a few jobs to do, tidy the wiring, wheel alignment, bleed brakes/clutch, etc but it's getting close. Oh, and it sounds really good, fruity but not crazy loud so I just have to hope the MOT tester agrees.
Last Edit: Mar 15, 2020 6:39:47 GMT by Ritchie
Awesome! Loving this thing.
1985 Volvo 760 "Jurbo"
Ritchie
@ritchie
I'm abroad working at the moment, if I manage to get home in the coming weeks and have to isolate myself the progress will be much faster! Every cloud and all that..
jmsheahan
Club RR Member Number: 121
Subaru Brat WRX.jmsheahan
@jmsheahan
Club Retro Rides Member 121
Loving this thread, it looks awesome! Keep the updates coming
Mar 17, 2020 11:32:25 GMT
OK, it is borderline criminal there isn't a video of this running.
What an epic machine. Great job!
Ritchie
@ritchie
Mar 17, 2020 11:40:18 GMT
OK, it is borderline criminal there isn't a video of this running. What an epic machine. Great job! Thanks, If someone could tell me how to upload a clip, I have a couple.
Mar 17, 2020 12:09:43 GMT
Upload to YouTube and post the link here? Do you know approximately what bhp you’ll have? And how much does it weigh? Looks fun
Ritchie
@ritchie
Mar 17, 2020 12:14:37 GMT
I'll give it a go.
It was meant to be approx 270BHP and I have rolling road printouts from years ago so how accurate that is I'm not sure. The truck weighs approx 900kg, roughly half the weight of the WRX!!
Ritchie
@ritchie
Mar 17, 2020 12:24:11 GMT
Give these a try... I hope I'm not classed as a yoootoober now?
Mar 18, 2020 13:54:13 GMT
Oh wow, I love it even more.
I need a Subaru powered something in my life!!!!!
Ritchie
@ritchie
73 seconds of fame. (05:20) Damn this bloody virus, I need it finished.
I was looking at a Subaru Leone wagon. That would be another cool candidate for this conversion.
Ritchie
@ritchie
I was looking at a Subaru Leone wagon. That would be another cool candidate for this conversion. Might be a bit easier as I’m sure there’s more room under the bonnet.
thomfr
May 10, 2020 20:47:47 GMT
Great job! I raise my hat for you! Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
nico
just read your journal on the little Brat !! great work you did on it all she's a beauty
1986 Subaru Leone RX TURBO STi
Ritchie
@ritchie
just read your journal on the little Brat !! great work you did on it all she's a beauty Thanks, it's a long way away from your standard though! I have to say I'm very jealous of all the rare & NOS parts you seem to be able to get. Can you share your sources for the goodies? Thanks.
That is so smart. Very jealous!
Keep up the great work
Subaru Brat WRX.Deleted
@Deleted
May 12, 2020 15:45:10 GMT
I browsing my photo albums for a particular pic and I realised I have never seen a Brat at one. Such cool wee trucks.
