Mike
East Midlands
Sept 3, 2018 10:12:13 GMT
4 x genuine Revolution 4 spoke alloy wheels - Ford fitment, 13" x 5.5" 4x108 pcd, rear wheel drive offset, so probably around ET18-20 (backspacing is about 85mm). Very straight wheels that have been hand painted at some point in the past so would benefit from a quick refurb. Very little kerbing (worst is pictured), no dents or buckles. All have 185/70 tyres of various different brands that are pretty old so will want changing. They come with a set of the correct flat-seat nuts for fitting (thread of nuts is M12x1.5). SOLD
Last Edit: Oct 28, 2018 6:46:33 GMT by Mike
JoshO
Sept 3, 2018 16:54:35 GMT
Any chance you could measure the centre bore of the wheels for me?
Mike
East Midlands
Sept 3, 2018 20:33:36 GMT
Any chance you could measure the centre bore of the wheels for me? They are 64mm as close as i can measure, so probably 63.5mm which would make them standard Ford fitting. Edit to add: the 64mm is the narrower portion of the centrebore in the last photo, the wider bit is 77mm.
Last Edit: Sept 3, 2018 20:35:37 GMT by Mike
Mike
East Midlands
Sept 11, 2018 8:31:51 GMT
Open to offers on these
Mike
East Midlands
Sept 21, 2018 18:15:36 GMT
Bump for a price drop
