steveg
Jul 22, 2018 10:21:11 GMT
I had to do a repair on my van yesterday, almost finished and ran out of gas. I had a couple of old disposable bottles to get it finished but it's made me wonder about how much I have actually used the bottle. The answer to that is not a lot.
I get them from a local company and they are the 10 Litre ones. Is there any easy way to tell you are getting what you pay for ?
When it's stored I leave the regulator fitted but turn the bottle tap off. I was wondering if it was leaking out over time.
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
Mig Welding Gas.fulvia1436
@fulvia1436
Club Retro Rides Member 63
Jul 23, 2018 10:07:39 GMT
As a failsafe, always wind the pressure right down at night
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
steveg
Jul 23, 2018 10:16:36 GMT
As a failsafe, always wind the pressure right down at night Yes I guess if the bottle leaked at all and the regulator is fitted turning it down as well would help. Does anyone know what pressure should be in a filled bottle ? Obviously only something I can check after fitting the regulator.
Jul 23, 2018 22:26:18 GMT
bottle should have a tare weight marked on it , you need to weigh the bottle then its a simple sum
retired with too many projects!
steveg
Jul 23, 2018 23:15:40 GMT
bottle should have a tare weight marked on it , you need to weigh the bottle then its a simple sum I didn't realise that, I will have a look and see. I've not ever been involved with filling bottles, probably been told about it years ago at college but have forgotten stuff like that I haven't used.
Jul 24, 2018 11:04:51 GMT
Isn’t pressure also going to be a variable?
Jul 24, 2018 20:26:05 GMT
the contents will weigh the same no matter what the pressure is
