Ok, this is not in its first flush of youth and need a fair bit of welding, but is MOT exempt and is tax exempt. The engine has a crack in the bock thats been repaired wth JB weld by the previous owner, but i havent had time to check if its sealed or not. Its current engine is the 360,it will come with a fully stripped for rebuild 318 as a direct replacement if the 360 is totally gone. I will also throw in an international 7L V8 diesel with C6 gear box (from a Ford F350) that needs a rebuild due to low compression (rebuild kits for it are apx $400)
I was going to make a rollcage to circumvent a fair bit of the welding as the roof is coming away on the left of the windscreen. Also as it is a separate chassis, it could be possible to put a different body on it.
I'm losing my storage for this so need to get shot of this sadly. If you have a sensible offer ill consider it,the buyer would also need to arrange collection. Any questions just ask and ill get back to you.
