May 21, 2018 17:32:14 GMT
I'm hoping some one here can shed some light on the possibilities and hopefully how-to of changing from the Volvo's original 5x108 to a 4x114.3 PCD. I don't like to use adaptors also since the axle is the ideal width as standard for my project. The main reason for me wanting to go with a 240 axle is the strength, availability (cost) and the width being spot-on. I need a significantly stronger rear axle and I know there are a couple of 4x114.3 around that are stronger but those are hard to come by and also much wider. And I don't think I want to know how much narrowing one of those would cost. On top of the original cost. I have found an example of it done. But no mention of how exactly this was done. But perhaps some will be able to see what's what.
Last Edit: May 21, 2018 17:33:37 GMT by Mavista
May 21, 2018 20:23:22 GMT
Easiest option i see is to get a brake disc with the right pcd you want. Then enlarge the centerhole to the right volvo size so it's a good fit on the axle.
Then you can try to turn it so your four holes fit in between the five existing ones. If that works out you can center the new holes, drill and thread them.
If not possible without hitting one of the existing holes you're in for some more work... Welding up the existing holes and putting the flanges in the lathe to get them nice and flat again. After that you can put in any pcd you want.
Rich
Club RR Member Number: 160
Jeep Cherokee XJ rear axle too far out of the width you want? Nearly Right PCD, and available with an LSD if that floats your boat.
ETA: nearly right PCD. Read as 5X4.5", sorry!
slater
Club RR Member Number: 78
May 22, 2018 10:34:36 GMT
You may have to weld up one of the original stud holes. Going from 4-5 stud or vise versa tends to be close. Otherwise can't see much issue.
Dez
Club RR Member Number: 34
May 22, 2018 12:08:31 GMT
Get a scimitar axle instead. Same width, correct PCD you want, equally as strong. (Volvo rear axles aren't as tough as people think as stock) Easy lsd or locker upgrades using jag parts.
May 22, 2018 15:38:59 GMT
Thanks guys. Wasn't sure it was 'OK' to redrill after welding up the existing holes since one or two would be overlapping with the 5x108 -> 4x114.3 Get a scimitar axle instead. Same width, correct PCD you want, equally as strong. (Volvo rear axles aren't as tough as people think as stock) Easy lsd or locker upgrades using jag parts. Now that's giving me a nice option, thanks! Are there significant differences between the different models? I found the SE6s to have a wider axle for example. The 51" of the SE5 would be very good indeed.
Dez
May 22, 2018 20:25:24 GMT
A Volvo 240 axle is 55.5". From memory I think a se5 one is 54" and a se6 56", but I'd have to check that.
May 23, 2018 14:28:34 GMT
My Scimitar 'knowledge' came from a 2 minute google search so might not be bulletproof. Either way the se5 would be the one to go for. Be it 54" or something close to it.
If anyone has one lying around or knows where to find one I'd be much obliged.
Dez
May 23, 2018 18:24:57 GMT
There's an se6 one on eBay at the mo, he lists it as being 144cm wide which is 56.6".
Se5 ones can be a little harder to find, just got to watch eBay and the hot rod forums/groups.
May 26, 2018 18:05:51 GMT
I had seen the one currently on eBay, thank you. I will keep my eye out for an se5 axle. There isn't a particular rush. So I assume one will show up one way or another.
Jun 11, 2018 16:19:17 GMT
Have you gave up on the redrill volvo one then?? I need axle to withstand 600bhp and not sure if an uprated 240 axle will handle it
mk2 ford orion mk2 cavalier sri mk3 cavalier sri 95 clio 16v mk3 cavalier gsi ford scorpio mk3 cavalier tdi nissan 200sx (s13) mk3 ford transit mk2 astra gte rep mk3 3.0 v6 cavalier mk3 fiesta van mk3 capri 1.6 mk3 3.0s capri mk2 polo bready 96 bmw 3.2 evo audi 80 tdi landrover 200 tdi mk3 g40 polovan mk1 facelift vauxhall carlton estate ford sierra vw polo 6n
