Sept 18, 2007 16:13:05 GMT
I have a bit of a dilemma. Currently, the tyres on the Benz rub on full lock. They catch on the inner wings as well as the arches so it isn't just a case of rolling the arches unfortunately.
It currently has 185/80 R14s. I could go for 175/80 R14 to try to clear the arches, but the profile means that it will lower the car by 16mm. And I only have around 25mm of ground clearance!
So... I'd be happy to live with the rubbing, but will the MOT man see it that way?! Can anyone think of any other options? (No, I'm not raising the suspension... that would just be silly!) Do they make 90 profile tyres?! ;D
markbognor
Club RR Member Number: 56
Rubbing tyres and the MOT manmarkbognor
@markbognor
Club Retro Rides Member 56
Sept 18, 2007 16:26:09 GMT
Could you batter the inner arch with a big hammer to gain a little clearence?
Would spacing the wheels out a little just cause more problems somewhere else?
paulb
Renault 9 Turbo
Sept 18, 2007 16:38:47 GMT
just fit some wheel spacers for the MOT, keep him happy as it will fail on this...
then , take the spacers off again when your home...Job Done
Injection is nice,I prefer being Blown
kee
Sept 18, 2007 16:53:51 GMT
but with spacers it will rub even more on the arches
Sept 18, 2007 17:39:36 GMT
Yeah it'll catch more on the arches if I space out the wheels . I could try rolling the arches more, but they're already pretty tucked under. Maybe I could use lower profile tyres for the MOT and get it down there with only 10mm ground clearance... might not get onto the ramps though! ;D I could "adjust" the inner wings, they don't rub much there. Or perhaps lots of negative camber although I think to get enough I'd need serious surgery. I was talking to Bodieanddoyle at RR07 and he reckons there's an adjustment you can make to limit the rack turning. I might have to investigate this further.
Sept 18, 2007 17:40:48 GMT
Good thinking. That's a cheap and easy method!
Dez
Club RR Member Number: 34
Rubbing tyres and the MOT manDez
@dez
Club Retro Rides Member 34
Sept 18, 2007 17:42:33 GMT
sorry to curse word on your chips, but it aint got a rack, its a box, and it doesn't have adjustable stops either.
Sept 18, 2007 17:50:14 GMT
sorry to pee on your chips, but it aint got a rack, its a box, and it doesn't have adjustable stops either. Knackers. Never looked at it that closely. In that case I'll have to look at where exactly it rubs and cut / shape / grind accordingly. I like the tall profile tyres cos it keeps the ride civilised.
Colonelk
Club RR Member Number: 83
Rubbing tyres and the MOT manColonelk
@colonelk
Club Retro Rides Member 83
Sept 18, 2007 17:57:22 GMT
Block of metal tacked/epoxy'd to lockstops on the front suspension arms? (don't know if the Benz has these, the senator does and thats a box)
Sept 18, 2007 18:01:10 GMT
what about just winding in some of those rubber donuts into the springs to jack it up an inch for the mot, then whip em out when ya get your certificate!!
Sept 18, 2007 18:18:20 GMT
I'd go with Boring! and have a spare set of narrower tyres for the test too. Rubbing tyres is a fail. Been there....
Sept 18, 2007 18:25:48 GMT
Rubbing tyres probably should be a fail, but my car just passed with such a condition. ;D
It's clearly visible aswell, because there is no paint on the inner arch where the tyres rub.
And no, i don't know the MOT tester, so i suppose it depends where you take it??
OAP drifta Volvo 340,Williams power 1960 Beetle twin 40's 1776cc
Sept 18, 2007 18:33:18 GMT
Wonder and Blunkett Autos FTW! ;D
Rubbing tyres and the MOT manstealthstylz
@stealthstylz
Club Retro Rides Member 174
Sept 18, 2007 19:07:51 GMT
My clio passed with rubbing arches, but the tester said as it was just the underseal that was gone and not down to bare metal it wasnt a problem.
Matt
Sept 18, 2007 19:15:50 GMT
if it rubs it fails. mwah ha ha ha!
Sept 18, 2007 19:16:44 GMT
Wonder and Blunkett Autos FTW! ;D Classic ;D
Sept 18, 2007 19:24:55 GMT
My Volvo rubs on full lock, and I have a sneaky suspicion that it always has. It's not lowered, the tyres are a factory size and it passes MOTs.
Sept 18, 2007 19:42:40 GMT
if there are witness marks on the tyre its supposed to be a fail.
I've had cars pass MOTs with all maner of defects in the past. In fact I complained to VOSA about one test they'd missed so much stuff. Not at my usual test centre of course.
Dave's an MOT tester by trade an 'all so I'd take his word on whats what...
koppak
Sept 18, 2007 20:59:26 GMT
It should fail but you may be able to sneak it through under the radar, how about running the mig down the lock stops a weld bead down each side will work wonders.
