Apr 29, 2018 20:47:34 GMT
I have been away from the forum for a while mostly because I am renovating a house and partly because I went and bought a Porsche 944. It's the sort of car that puts a smile on your face when you drive it. Very long box, so it's happy doing bends between 40mph and... loosing your license. It is a car that I bought for probably 2k too much but it's solid. It needed a heap of small, annoying jobs done: Sunroof opening but not closing - waiting in sunroof switch replacement and limyer switch No.2. Rear hatch sticky - replaced gas struts and both latches and also the latch rubbers and pins. Oval dash - broken and missing mileometer zero. Steering wheel - past it's sell by date. Heating facia panel replaced. Glove box light fixed and replaced. Gear stick boot replaced. Radiator overflow insert broken and leaking fluid onto the fan draining the battery - replaced whole radiator with a full Aluminium one. Instrument cluster - heat dial fixed, changed lights to LED's. Micro switch on OS door handle dicky so replaced. Clock not working and found a second hand one for decent money. Cracked front fog light replaced. Cracked front OS indicator lamp changed. NS wheel arch replaced. Fuel pump replacement. Bought a complete interior screw kit from the US. Sooo handy. Still need to: Replace headliner. Sort out intermittent stutter under acceleration (speed sensor). Sort out electrics on passenger seat. Replace door lock barrel on drivers door. Replace fuel filter to pump pipe (it's in a box in the corner, and the old one os holding up). These are pics I took not long after buying it and after detailing the bodywork and giving it a Fusso soft coat.
How will I get this one passed the missus...
Apr 29, 2018 21:18:29 GMT
I was ( long time ago) looking at a 928s. I ended up talking to a gentleman and he told me that all 928s' were $50.000 He said if you buy it for $10.000 you have to spend $40.000. Buy a good one for $45.000 and you only have to spend $5000 to make it your own. I think that $50.000 might be a bit rich but I do believe the essence of the story. Better pay a bit more and have a good base than buying a pile of cr@p for little....
Anyway I really like your car
Oct 30, 2018 17:57:58 GMT
Beautiful! And nice to see another black 944 in Scotland :-)
1974 Skoda S100 tarmac car 1998 BMW 750 daily 1994 Mitsubishi Evo2
Oct 30, 2018 21:49:50 GMT
Have you got one Raymond?
Oct 30, 2018 22:14:05 GMT
I had a fire in mine: Failed FPR O ring...
Wind the clock forward 4 months after replacing some of the harness in the engine bay, New fpr, new vacuum lines, new HVAC, a heap of soldering, (change of batteries in the multi meter!), new inlet manifold gaskets, new temperature sensor, refurbished injectors...
In fact, here is the complete jobs list! (So far)
[Porsche - Clean it, wax it, drive it, love it, fix it. Repeat infinitum]
Porsche 944 jobs list 1. Changed radiator 2. Changed lower half of air intake filter housing (broken stud bolt on old one) 3. Replaced both door carpet/rubber seal lower trim and loom protection (kick) strips 4. Fixed micro switch operation on drivers door 5. Fixed key barrel on drivers door, replace parts 6. Replaced rear hatch pins 7. Adjust ‘clams’ for rear hatch 8. Replaced linkage to hatch release lever (N/S) 9. Replaced bonnet release assembly interior ‘plate’ 10. Replaced rear hatch interior remote button 11. Fixed sunroof... temporarily 12. Replaced O/S indicator 13. Fixed fog lamp O/S 14. Re position rear wiper arm, lubricated mechanism 15. Fixed passenger side electric seat operation (tilt) 16. Fixed drivers seat tilt function. 17. Soldered new connector block to seat belt connector (gong activation I presume but no gong relay in fuse box!). 18. Paint both seat runners and lubricate (steam cleaned carpets whilst seats were removed). 19. Replace carpet trim ‘buttons’ in rear hatch well 20. Replace rear hatch struts 21. Repair instrument cluster, insert reflective foil and LED instrument lighting 22. Replace cracked heater facia panel 23. Replace cracked left lighter/hazard/rosette panel 24. Replace oval dash (missing vent slat parts and broken odometer reset button). 25. Replace missing screw cover (left dash) 26. Replace/insert missing/incorrect interior screws and spire nuts 27. Total strip of floor pan and underseal 28. Replace fuel pump 29. Replace filter 30. Replace filter to pump fuel line 31. Replace filter to fuel line section of fuel pipe 32. Source correct air intake pipe and boot to inner wing and fit 33. Replaced steering wheel 34. Replaced gearstick boot cover 35. Paint front (scuffed) speaker covers 36. Fix under bonnet fuse box courtesy light (need to solder after removing butt connectors at later date) 37. Replace glove box light 38. Solder wiring to rear hatch light (removal of more butt connectors) 36. Solder new connection block to drivers seat belt warning 37. [Replace old bolts for SS at every opportunity whilst doing work] 38. Replace rear hatch pin boots 39. Replace rear hatch key barrel rubber 40, Fix non returning rear hatch key barrel – broken return spring 41. Change HT leads, rotor arm, plugs and dizzy cap 42. Replaced front 2 hydraulic engine mounts 43. Sourced and fitted front plastic mount for drivers door well 44. Replaced secondary intake heater flap rod clip 45. Replaced hazard light button on dash 45. Re-align O/S door and replace door catch (needs welding, cannot improve door shutting). 46. Replaced heater under bonnet cowling. (Ended up repairing replacement – needs another). 47. Replaced rubber bushes on air intake box mount (x4) 48. Replaced Orange O ring on AFM. 48. Fixed rear hatch light 49. Replace O/S front wheel arch 50. Sent injectors off for refurb. 51. Acquired correct fuel pressure regulator 52, Replaced rear hatch motor (defective ‘C’ copper track in motor) 53. Remove passenger door card and search for rattle/re-position plastic cover 54. Replaced sunroof limit switch 55. Investigate seat belt and warning light gong’ relay/operation. Discover it hasn’t got one. Thank f*ck for that. 56. Replaced broken/bodged throttle pedal 57. Replaced clutch and brake pedal rubber 58. Repaired centre console. Fix centre console to mounting points with new spire nuts. 59. Re-aligned sunroof o/s guide rail to allow locking function of sunroof. Still not good. 60. Replaced water temperature sensor on engine block. 61, Fit new gaskets to inlet manifold to engine block. 62.... [Repetition] 63. Re-seal inlet heating tube 64. Replaced all heating/water system pipes with SS Jubilee clips. 65. Fit injectors, injector rail, Fuel Pressure Regulator pipe and new FPR 66. Fit correct Bosch spark plugs 67. Replaced wiper arm assembly 68. Repaired heater blower cover, paint, replace parts, replace screws/bolts etc 69. Fit new connecting rods to wiper arm assembly 69. Replaced fuel lines 70. Replaced sunroof arm receptacles. Sun roof now operating properly. 71. Replaced rear hatch clams and actuator levers 72. Replaced non return valve on fuel pump 73. Replaced wind screen washer jets and soldered heating wires. 74. Soldered sections of washer electric and bonnet courtesy light (removing butt connectors in process) 75. Replaced starter motor with new Bosch one.
To do:
Cam/balance shaft belt replacement Sump gasket replacement Water pump replacement? Inner and outer front anti roll bar bushes
Fire damage repair (after drying everything out. Thanks Fire services; I had got the fire out you know. If I had waited for you, it would have been toast.)
1. Strip parts of loom for investigation. Done 2. Clean. Big clean. Big, big clean and painting of multiple brackets/replacement of old bolts/screws with SS equivalent. Done 3. Re solder and splice in replacement injector leads from donor. Done 4. Replace lost vacuum pipes. Done 5. Replace crank shaft reference sensor. Done 6. Replace heater vacuum valve {HVAC). Done 7. Repair and solder O2 sensor plug in point. Done 8. Source re-useable cable tie mounting for loom. Done 9. Replace and splice in starter motor lead connector block. Done 10. Replace throttle cable. Done 11. Source incorrect Fuel pressure regulator. Done 12. Find FPR pipe with screw fitting as opposed to push fit. Adapter being fitted by indie Porker coy. 13. Replace bonnet insulation. Done 14. Check continuity/resistance of all new wiring through ECU bus/relays/fuse box etc. Done. 15. Re-insulate exposed loom with impregnated Chloroplast tape. Done 16. Ferrous treat/paint ECU housing and protection board. Done 17. Source 2 x ECU mounting board screws. Done 18. Position ECU correctly in mounting as opposed to previous bodge . Done
Asleep yet?
broady
East Midlands
Oct 31, 2018 21:22:46 GMT
I got to 19 before my eyes wandered!
Nice to see another 944, they are getting few and far between these days
