As per the title I am seeking the basic efi parts to convert a carb equipped engine to injection, its not a Ford but has the majority of the sensors and is a free breathing 16v.
I'm presuming a list as follows?
Engine loom
Manifold with T body and injectors/reg.
Induction pipe and Afm.
Ecu that can be easily ran with or without pats.
Oxy sensor.
Not sure about the rest although minor parts like temp senders and the fuel pump are easily found
So the above if there is anything more required that's all good and hopefully fairly close to the Midlands, I've got 150 to spend but can adjust if really necessary
Many thanks
Engine loom
Oxy sensor.
Many thanks
