Apr 11, 2018 22:37:11 GMT
Hi guys, I've done a fair bit of reading on Google, and I can't find anyone who's done it. Quite a few have tried taking 4.5mm off the tyre bead so that a 15" tyre will fit, leaving a bead mounting wall of 2mm thickness. Well I've done some measuring, and I reckon I can make a 390mm trx into a 16" fairly easily. Pictures to follow next week before I Chuck one up on eBay to confuse people
Apr 11, 2018 23:00:02 GMT
using a lathe hopefully!
Apr 11, 2018 23:06:28 GMT
I was just going to build up the edge with some chemical metal, mount it up on the rear axle of something and hold a grinder on it with a 40 grit flap wheel on a 115mm grinder.....
Apr 11, 2018 23:17:26 GMT
What 8mm, that's a lot of chemical metal?
Apr 11, 2018 23:23:00 GMT
What 8mm, that's a lot of chemical metal? 8.2mm
Apr 11, 2018 23:23:53 GMT
What 8mm, that's a lot of chemical metal? yes well...you cant use plaster of paris
Apr 12, 2018 17:31:37 GMT
There we go, 390mm TRX alloy converted to 16"....easy pips
Apr 12, 2018 19:19:35 GMT
01alam
Apr 13, 2018 12:25:00 GMT
Interesting...I have 390 on my CX and would need some new tires and was thinking about 15" stretched...but your idea is better - also I remember there was some sort of discussion for Mondial or 308 about people looking to do that...
Citroen CX DTR Turbo 2 Citroen Xantia Activa CT Ford Granada Scorpio Volvo 240 SE Volvo C70 Renault Wind
Past... Audi C4 A6 Ford Mondeo Verona LTI TX1 Mazda 5 Mercedes W114 280CE Mercedes C107 450SLC Skoda Yeti
Apr 14, 2018 13:27:20 GMT
yea but the ferrari boys can buy repo wheels in imperial sizes...so not really worth them having modified wheels.....where as your cx and granadas don't
