Vauxhall viva project, this is a viva without any rot, no corrosion anywhere, it's been fully restored underneath, and under sealed, all the metal painted, including the axle, new shocks, the car originally having done less than 40k miles
new everything, brakes, it was a 1800 auto so a strong decent ratio diff model, now fitted with manual pedal box,
the suspension has been polybushed, and undersealed, the engine semi fitted is a rebuilt Vauxhall cavalier gti motor, fitted to a manta gte manual box, there's a Vauxhall 1.7Td engine included, another spare manta box, the one that connects to a red top Vauxhall’s engine and a Vauxhall omega box,
there is a manta distributer. That runs of the cambelt conversion included,
all the wiring to run the engine, including the Cdi,
BMW E30 brake disc axle mounts(unfitted)
a set of black and silver number plates
and a set of new in the box GB alloys, without tyres, brand new, never had tyres fitted
there's a couple of driveshafts and a new tow bar to fit,
it just needs painted and one engine mount welded to the crossmember, and the driveshaft adjusted to fit,
there is a full set of stainless wheel bolts, new front window rubbers and windscreen rubber
All the original parts are with it, it can be pushed
I may sell the spare boxes and Diesel engine separately,
an imminent house move forces sale, it will need to be moved on a car transporter or trailer.
I can even include an Apollo spray system for £150 exrra
Pictures to follow
ibb.co/album/ifctfa
Pictures to follow
ibb.co/album/ifctfa
