Might seem daft, but here goes!
Fitted a Cruise Control to the Delica this one
It's pretty simple, the hardest part was running the wires! But it doesn't work, the little LEDs that are meant to light when the ignition is switched, don't.
The control box has a 12V permanent feed and also a 12V ignition switched feed. I've pulled the connector from the control box and tested both 12V feeds and they work fine.
It's got to be a faulty control box? Or am I missing something, if the LEDs light and the system didn't work, then it's most probably my dodgy wiring, but there's nothing, even though the 12V feed's are "feeding"!
Any thoughts?
Any thoughts?
