BMW E46 M3 : That's the ticketballbagbagins
@ballbagbagins
Club Retro Rides Member 164
I've recently refurbished a pair of Porsche brakes for my golf. I took all the paint off by sanding them down as I wanted to get them super smooth, working up from coarser to finer sandpaper. I used my black and decker mouse sander. I took all the casting marks off.
I spent a good while on them so they had virtually none of the surface texture left.
Then two coats of vht primer, two of colour. I put the porsche script sticker and and applied definitely more than two of vht clear.
Then i fitted the seals, pistons and bleed nipples.
I chose a Kawasaki like green which looks excellent on the smoothed calipers. Maybe going for darker colour would mean all the sanding prep wouldn't make much difference to the finished caliper.
MiataMark
Club RR Member Number: 29
Not quite the same scale but I refurbished all the calipers on my MX5 (well the fronts were second-hand bigger ones), I soaked them in citric acid, bit of wire brush action then painted with hammerite. Big Redd rebuild kits and I think they turned out well, not sure how long the paint will last but easy to touch up if needed.
Quite a therapeutic process really.
BMW E46 M3 : That's the ticketChasR
@chasr
Club Retro Rides Member 170
Well, today I've made a decision on the calipers. I'm going to the following to them -Grind the calipers down as I have been -Strip off any remaining paint with paint stripper -Put them into Bilt Hamber Deox C : I don't think this can remove paint hence the above step -Paint the bodies; I'm unsure of colour. it will most likely be black or a dark grey with the M insignia painted on them possibly. -Rebuild them with the new nipples, seals and brass sliders. I've ordered some Deox C, so at least now, I can grind the rest down and get the worst off them . Taking apart the first one as you say is therapeutic. They are easier than the Merc ones to rebuild, but even they were not too bad; but I was against the clock to rebuild those as well to be fair.
@ballbagbagins
Get M decals rather than stencil the M logo on. It will cost more but there is zero chance of them bleeding and you having to repaint them.
MiataMark
The calipers I had were painted (probably badly and not caliper paint) most of which got removed by the citric acid so you might get lucky.
The only issue I had was getting the piston outer seals on, until I looked on YouTube.
@chasr
May 16, 2020 13:23:31 GMT
Get M decals rather than stencil the M logo on. It will cost more but there is zero chance of them bleeding and you having to repaint them. I'll have to get them in the right size I suspect. But I'll have a measure and see what's about . While I was waiting for the materials, and the caliper to arrive, so as to complete the caliper refurbishment, I finally started yet another job I've been putting off for some time. The door handle trim replacement. The M3 is one of the few cars that I've owned where I have not removed the doorcards. I'm normally not a fan of removing doorcards where the fixings are likely to break or the doorcard mounting itself is likely to break. To prepare for this, I bought a special trim tool I saw Ed China on Wheeler Dealers (I know I know!) use when he tackled things. I know it doesn't just affect me, it is simply down to the fact that these parts weren't necessarily designed to come on and off often. With that in mind, the doorcards were off and thankfully undamaged . Amazingly the clips managed to survive too; that was a real surprise! Furthermore, I've seen people at the dealers and on forums guess where the clips are on the doorcards, with very patient dealer operatives trying to see what clips go where. Thankfully I've managed to figure out what is the case ; RealOEM does not clearly show which go where. The arrangement for the clips is as follows: Top/Rear part of the door : 7 x White clips Front of the door by the speaker : 2 x White/Grey clips with a rubber surround Upper Front of the door : 2 x Yellow clips. Why are they different? I don't know. My guess would be the rubber surround clips are to reduce speaker vibrations, and the other two clips are process led from when the car was assembled, probably to account for the doors having airbags in the ; A first I've seen ; My newer Mondeo doesn't have these; Maybe these are more modern than I thought!! Of course, something was missing from the doorcards. The handles themselves! As you can see, this is the reason why I wanted to change them. Almost 20 years of terrified passengers was causing one of them especially to start cracking alot. Not what you want on an M3! Patina or just shot? I'll let you folks decide: Interestingly, these trims are dated for 2005, insinuating that these were changed at some point very early on in the car's life. Maybe it was a warranty claim, who knows! These were put onto the bench, and I then tackled the issue of separating them. This was a very awkward job. It's a miracle I didn't manage to break any clips, as many on them are blanked off, so you have no means of releasing them. When people said these needed brute force, they weren't kidding! However, some patience and perseverence had these reassembled in the new Carbon Cube items I fitted. Oddly, these are dated for 2001, but at least they are fresh refurbs. To remove the armrests, this plier tool came in very handy once more. Before I knew it, the handles were reassembled . While there is no doubt that they're an improvement from the old ones, I may refinish the originals. I had ideas of either painting them Carbon Black or Mystic Blue (the car's colour) or maybe something different, depending on how another potential trimming project goes in the car . I guess for now, I should probably start to refit some of the stuff back in the car, and crack on with the caliper refurbishment, now that all of the materials etc. have arrived. There is no time like the present after all. Off the back of this, I've started enquiring about bodyshops to attend to the wings and the rear arch. Maybe @grumpynorthener feels up to the task . Other places I'm debating include Spa Garage and EMC Motorsport in Brum .
May 16, 2020 17:24:33 GMT
Not a problem if its a short term job - the larger restoration type jobs have a lead time of a good few years but the smaller turn around type stuff is not an issue - I'll leave the ball in your court
@chasr
May 17, 2020 12:38:12 GMT
Not a problem if its a short term job - the larger restoration type jobs have a lead time of a good few years but the smaller turn around type stuff is not an issue - I'll leave the ball in your court I'll have to grab some shots of the stuff . A PM will be on the way eventually . However, in the meantime I made a start on refitting the doorcards But firstly, I'd need to fit the handles. Eventually, I got them back on. Annoyingly however, I had two two doorcard clips! Normally, like most people I'd just put the doorcard on and hope for the best! But I do like a job done right. As a result, I'll put an order in for an assortment of clips. It seems my theory is correct. The door handles and trim must have been replaced under warranty on this car. The doorcard dates imply that they are original to the car still. It did not stop me however, from getting one doorcard on however. In truth, the Carbon Cube actually works better than I thought inside the car, and dare I say it to the purists, an improvement from the Titan trim for this interior combination. The keen eye would have noticed that the gear selector dome is still Titan in colour. While it doesn't look as out of place there as I imagined, I do have a plan for it.
@chasr
There is another update coming, but the times have not been great for this for the brakes.
Despite using Trade-spec paint stripper, the paint is either coming off very easily or being an absolute pain to remove! That stripper normally removes anything!
I don't think they've been powdercoated, but whoever painted them did a decent job!
As a result, I think my plan for the refurb may upset some people! Sure, I'll clean them and fit new pistons etc. but I will have to do something different with the bodies in the absence of a sandblaster (and I suspect it would take a while for even that to take this paint off ; a couple of the areas, had the paint stripper not even touch the paint!
@chasr
In the meantime, I did however get the car back from the unit. It was pretty filthy outside, not a surprise from it being down there for quite some time now and no running water sources there. I may have to invest in a 'waterless' wash like AMMO Foamy to save the dirt baking on like it did. Despite that, with -A snowfoam left to dwell quite long on there -A couple of washes -Some Bilt Hamber Wheel cleaner ; this stuff gets a top product approval from me, which is surprising! It actually scrubbed up OK. It's a shame the calipers won't play ball quite as easy But at least I have plans for other parts. Now, those damn calipers..
@chasr
I left this tale talking about the calipers. The truth is there has been progress on them! However, my attention has been distracted from sorting them out. Why? I had turned uckly ducklings into swans! How? Let me explain. If you look back through previous shots, You'll see my 19" wheels were a Smoked Chrome finish. I originally liked this finish, but I was not so keen on them as soon as they got even remotely dirty. The lustre just went away and they looked like very dirty wheels! Obviously I needed a change of finish. What would I do? Well, as I hinted to vitessetony, BMW did a certain finish on these wheels, but it never lasted. However, where this a will, there isn't always a way. There can be a compromise however. A compromise which would look something like this! I have more images, but I am trying to get something which is better than a phone image . Hopefully I'll find something better I can take before I use the phone images . That is all for now .
@chasr
Jun 16, 2020 16:47:08 GMT
Wheels. They are a little like a pair like shoesto a wedding. They can make or break the look of an outfit if you are going to certain occasions, like weddings etc. In this case, it seemed it may be the case too. I have deliberated for a long time on what wheels to fit on my M3. It's time for a bit of a history lesson. Try not to fall asleep however, like I used to, even during Apocalypse Now being shown! Maybe it was the effect of the teacher being there, who knows? Anyway, I digress. Back in 2000, the E46 M3 was released to the public with the 18" wheels mine currently has, but in Shadow Chrome, shod on 225/45R18s and 225/40R18s. Some people love them, citing the handling benefits. To me, I was until recently never that keen on the wheel design. I like E46 M3s long before I bought one, but never with these wheels. It's funny, I don't mind mine with them on. I did debate getting rid of my undersized tyres (225/40s and 245/35s) for another set of fresh rubber, but decent rubber isn't quite as easy to get as it used to be. Until Goodyear released the F1 SuperSport in this size. Before then, your choices were F1 A2 RunFlats up front, and A3s at the back. With the exception of Yoko AD08Rs of course. Another in Topaz and a mild drop: Around 2002(ish), the 19" wheels were offered as an option. They came with Polished & lacquered faces, but with dark inserts: Obviously, not many people do a polished finish, with lacquer on top, with the exception of PureKlas. However, they do not lacquer them. But then, that's due to the lacquer not being long lasting. Diamond cutting is another option people undertake for refurbing these wheels. However, there is a limit to how often wheels can be cut. As mine have never been cut, that was an option. However, it again has problems with longevity: Now of course, there are more durable options to consider Quite a few people paint them silver. To me, this is a bit of a cop-out. It looks like someone went cheap, and genenrally, it's something I've seen on alot of specialist prepared cars. But that's just me: You then have other choices. More simple colours like Anthracite or Black, or what my wheels had on, Smoked Chrome; A darker Shadow Chrome. It seems deep down, I want the moon on a stick. The Shiny finish of the factory wheels but without the drawbacks. What would my solution be? Like all best-laid plans, it was simple. -Dark inserts -Chrome Faces With that in mind, I found a local powdercoater who could do this by chance a while ago, courtesy of RetroWarwicK . Then they finally came back. Despite me trying photograph the car during a rainstorm, the images didn't come out quite right on the SLR! So I'm afraid the phone camera shots will have to do! Argh! Who am I kidding? I may as well show some of the crappy SLR shots! It doesn't really show the shine, but then I guess when rain clouds around for as far as the eye can see, that's inevitable! Still, at least they look OK eh?
@ballbagbagins
Jun 16, 2020 17:17:49 GMT
Nice middle-ground colour between the super shiney options and the black/anthracite colours. Too dark and you'd have lost the wheels into the tyres.
I don't normally like those wheels at all, but I do in those colours. Goes well with body colour and the ambers.
MiataMark
Jun 16, 2020 17:30:38 GMT
Nice,
I've just got a 118i with 17" sport wheels (type 379) with awful lacquer peel etc. Now wondering what to do with them, or change them completely.
Would like to move away from run-flat tyres as well, can you use normal tyres on these wheels?
@chasr
Jun 16, 2020 19:39:16 GMT
Nice, I've just got a 118i with 17" sport wheels (type 379) with awful lacquer peel etc. Now wondering what to do with them, or change them completely. Would like to move away from run-flat tyres as well, can you use normal tyres on these wheels? Ah, I know the design! The Z3 from Flipping Bangers had a set of these on . As for moving away from run-flats, my dad did this on his E61 535d. In his case, the tyre profile was also 5% smaller all round on the run-flates,(225/45s vs 50s). The smaller run-flats were winter tyres however. However, going over to the non-run-flat 50s was a revelation. It was comfortably before, but it was not pleasant over bumps etc. As soon as I put them on, it was far more comfortable to drive. I was shocked at the difference. In your case, I guess this finish is an option if a powdercoater can do it for you. A bright Shadow Chrome may also work . I almost did the latter with mine .
Battenberg
Time for Cake....
Jun 16, 2020 21:26:22 GMT
Sorry for the thread hi jack, I changed my 640d from run flats to non run flat Yokohama’s and the difference was very noticeable, the rolling resistance decreased, more comfortable and quiet and the fuel economy also increased, an all round win win.
Current Fleet: 1968 Wolseley 1000 2022 BMW 430xd MHT Coupe 2007 L200 Animal - Dog walking transport 1998 318is Coupe 2007 Mini Cooper Supercharged 1989 BMW 530 - in storage
bstardchild
Club RR Member Number: 71
Jun 16, 2020 23:35:46 GMT
Sorry for the thread hi jack, I changed my 640d from run flats to non run flat Yokohama’s and the difference was very noticeable, the rolling resistance decreased, more comfortable and quiet and the fuel economy also increased, an all round win win. My daily had run flats when I bought it - absolutely horrid harsh ride little or no feedback from the tyres and on top of that one of them developed a 3 inch split and went flat so I binned them and put a set of uniroyal rainsports On non run flats it's bloody lovely - you can actually feel what's going on underneath you now
MiataMark
My daily had run flats when I bought it - absolutely horrid harsh ride little or no feedback from the tyres and on top of that one of them developed a 3 inch split and went flat so I binned them and put a set of uniroyal rainsports On non run flats it's bloody lovely - you can actually feel what's going on underneath you now I'm assuming that's with the original (18") wheels?
bstardchild
Jun 17, 2020 16:29:47 GMT
My daily had run flats when I bought it - absolutely horrid harsh ride little or no feedback from the tyres and on top of that one of them developed a 3 inch split and went flat so I binned them and put a set of uniroyal rainsports On non run flats it's bloody lovely - you can actually feel what's going on underneath you now I'm assuming that's with the original (18") wheels? Yes 18's in a staggered fitment I should probably say I fit XL rated tyres to replace run flats (I don't want the tyres to become the suspension if you understand what I mean - the run flats have a really stiff sidewall and I think if you didn't run XL you'd lose a lot of precision in the steering) I also run a square set up on steel 17's (winter tyres) for nasty months in the year Rides even better on them too on our curse word roads but it's definitely a lot less precise in terms of where you point it - probably the level of tread block movement, softer compound and more flexible sidewalls - it would probably be similar on non XL rated normal tyres
Battenberg
Time for Cake....
Jun 17, 2020 19:03:06 GMT
Again
Apologies for the hijack, but ^^ looks bloody lovely IMO on steels....
