Feb 11, 2018 20:01:38 GMT
What have you got held together with the wonderful bits of plastic....... My 146 has them on both bumpers and front fog housings and my daily fiat has 1 wheel trim helped to stay on with them..
Bicycle x1 Alfa Giulietta (now wife's) Alfa 156 BMW 630i Honda rc36
Feb 11, 2018 20:02:35 GMT
women to a bed does that count lol
Feb 11, 2018 20:24:01 GMT
The left hand sleeve of one of my sets of overalls is loosely stitched with them.
They're also an excellent way to hold the plastic arch extensions onto a Defender.
ivangt6
Club RR Member Number: 132
Cable tie magicivangt6
@ivangt6
Club Retro Rides Member 132
Feb 11, 2018 20:31:50 GMT
The dog ate the shoelaces on my doing things on cars shoes. now replaced with 3 rows of cable ties
1979 Mini 1000 1972 Triumph GT6 2007 VW Golf GTi 1979 VW T25 Leisuredrive 1988 Range Rover Vogue SE
Feb 11, 2018 20:36:53 GMT
Oh wow, can’t even think how many trucks I’ve ‘bodged’ on a ‘get you home’ basis. A few I can think of, throttle linkages, broken air valves, air tanks, with the really thick ones, when drivers had ripped the tank straps off up the pit tip (if you are 30 or younger, ask your Dad re. a pit tip 😉) interior door straps, gear linkages, holding batteries in, & loads I can’t think of atm
Feb 11, 2018 20:52:53 GMT
Can't believe no-one has mentioned plug wire separators yet!
Feb 11, 2018 20:57:23 GMT
Holding my undertray together and to the car.
Feb 11, 2018 20:59:21 GMT
managed to get my BMW home with a few big cableties acting as an aux belt to spin the alternator and water pump.
Feb 11, 2018 21:03:58 GMT
Can't believe no-one has mentioned plug wire separators yet! They are a work of genius
Feb 11, 2018 21:51:43 GMT
Can't believe no-one has mentioned plug wire separators yet! They are a work of genius This needs a video
Feb 11, 2018 21:57:58 GMT
I likes that. Black cable ties on my shopping list for today then!
Feb 11, 2018 23:58:01 GMT
i prefair my use lol
Cable tie magicChasR
@chasr
Club Retro Rides Member 170
Can't believe no-one has mentioned plug wire separators yet! Someone watches Roadkill! I like how simple and tidy the HT separator is. However, separating the wires if a couple of them go can become a pain . Me? Erm, undertrays as a get me home fix (it's surprising how many garages do this and then have people complain later that their tray is flopping around. I've used countless many for tying wires out of the way of moving things and during the LPG days I used them to secure the engine looms. I've used them on wheel trims many times. Best one I've seen is hoopsontoast . That was the renewable exhaust hanger. I say renewable as they would always keep breaking despite having 7 of them holding the backbox up!
Last Edit: Feb 12, 2018 8:42:28 GMT by ChasR
Feb 12, 2018 10:43:29 GMT
Backbox hanger - worked for months until it stretched, and they're currently holding the radiator to the brackets in my Astra until I drill out the snapped bolts Oh and they're holding the hid ballast tight against the inlet wing on my vectra, bodgers best friend
Feb 12, 2018 11:12:56 GMT
I've done bumper stitches frankenstein-style before after ripping the front on a low curb. I believe it's big in the drift world but worked great on my A2 Like this but neater
MiataMark
Club RR Member Number: 29
Cable tie magicMiataMark
@garra
Club Retro Rides Member 29
Feb 12, 2018 11:23:02 GMT
Holding my undertray together and to the car. Me too, plus the door sill trim and gear lever gaiter on the Discovery.
Feb 12, 2018 13:02:30 GMT
Body undertrays on most of my cars: Standard.
Heater cable to heater unit on the Capri is held in place with a clip that's collapsed: now cable tie. Front spring to strut on the Capri (to hold in place when jacking up) are held on by cable ties.
Passat rear window to runner plastic plug (stopping the window from going down): Now a cable tie
thebaron
Over the river, heading out of town
Feb 12, 2018 13:41:03 GMT
Many many things on the Starlet. As it gets constant bangs while competing I like to be able to tear it apart as quickly as possible.
If a panel or piece has 6 bolts/screws holding it on I'll reattached 2-3 and Zip tie the rest.
Off the top of my head:
Rear Bumper (I have created a quick release with bonnet pins and steady the edges with ties Front Bumper (The bars are quite mangled from various excursions so not everything lines up for bolts) Front Grille Rear Seats (they are purely for show as they need to be "present" for NCT purposes) - No nuns or kittens are/will be harmed
I also have a number of spare belts tied to the strut brace as required
Last Edit: Feb 12, 2018 13:47:52 GMT by thebaron
Feb 12, 2018 17:42:00 GMT
Badger
Feb 12, 2018 21:20:17 GMT
The radiator on the Dolly is currently held in with cable ties - more securely than when I bought it! Only a solution until I finally get around to restoring her.
