Hi all ive just replaced the diif on my car and the old one had a trigger wheel for the speedo pick up the new diff won't accommodate the trigger wheel so I need to relocate it and I was thinking of placing it in the propshaft but this will change its ratio via input speed
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
This is the wheel It has 48 teeth The final drive is 3.54:1 My calculations sergest it would need to have 13.7 ( let's call it 14) teeth over the same diameter to get the correct speedo reading Now I was thinking of removing some teeth from that wheel to achieve this You can see from the tip ex marks ive put on it what I had in mind IE "leave one tooth remove two teeth leave one tooth remove two teeth and so on" this will give me 16 teeth in total Now the question is will this work or will the teeth need to equal lengths
Phil H
Club RR Member Number: 133
2 trains of though and it will depend on the electronics in the speedo head to be honest. You might need to make the teeth 3.5 times wider - or in other words, fill in the gap after the tooth being left (with weld?), then remove the next tooth so your mark/space (or tooth/air) ratio remains about the same.
mk2cossie
Club RR Member Number: 77
In what respect will the new diff not accept that speedo ring? ![:D](//storage.proboards.com/forum/images/smiley/grin.png) As I'd be inclined to keep what you know works and reads right instead of (no offence intended here) lashing something together on the propshaft ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Darkspeed
Club RR Member Number: 39
You may also want it balanced if whipping round at prop speed.
2 trains of though and it will depend on the electronics in the speedo head to be honest. You might need to make the teeth 3.5 times wider - or in other words, fill in the gap after the tooth being left (with weld?), then remove the next tooth so your mark/space (or tooth/air) ratio remains about the same. I never thought about that something for me to look into
You may also want it balanced if whipping round at prop speed. I was going to fit it Inbetween the gearbox and prop so shouldn't affect prop balance
In what respect will the new diff not accept that speedo ring? ![:D](//storage.proboards.com/forum/images/smiley/grin.png) As I'd be inclined to keep what you know works and reads right instead of (no offence intended here) lashing something together on the propshaft ![;)](//storage.proboards.com/forum/images/smiley/wink.png) That was the plan until the diff arrived The body/casing on the new diff is the same diameter as the trigger wheel so no way of fitting it
Old and new
mk2cossie
Ah, i see now. Presumed it was external to the casing. Could you mount the ring (or another one made up) on a driveahaft flange and mount a sensor like TVR or Vauxhall Omegas have?
Ah, i see now. Presumed it was external to the casing. Could you mount the ring (or another one made up) on a driveahaft flange and mount a sensor like TVR or Vauxhall Omegas have? It's a live axle I did think about fitting it at the wheel end like a ABS ring but it has disc brakes with handbrake shoes so I can get it in there
froggy
What about the front wheels ? Any o-e options for abs hubs ?
nothing much to add but that's a monster lump of metal just to act as a trigger wheel for the speed sensor!
What about the front wheels ? Any o-e options for abs hubs ? They never fitted ABS to this model but I will have a look at the front end to see if I can accommodate a trigger wheel
andyborris
Feb 10, 2018 15:39:12 GMT
Or a GPS speedo.
Feb 10, 2018 15:46:41 GMT
looks like it mounts using the CROWNwheel bolts, the CROWNwheel still mounts with the same bolts so I can't imagine it being far off?
sonus
Feb 10, 2018 21:02:20 GMT
Been there done that and it is a pain when you loose the GPS signal ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
sonus
Feb 10, 2018 21:03:54 GMT
What diff is it for? I am making a trigger wheel for the output flange on my Jag diff that will bolt on between the drive shaft and flange EDIT: Sorry didn't read the bit about it being a live axle ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Last Edit: Feb 10, 2018 21:06:24 GMT by sonus
Feb 10, 2018 22:44:34 GMT
looks like it mounts using the CROWNwheel bolts, the CROWNwheel still mounts with the same bolts so I can't imagine it being far off? The holes are just for show its interference fit onto the diff casing opposite end
Feb 10, 2018 22:51:20 GMT
What diff is it for? I am making a trigger wheel for the output flange on my Jag diff that will bolt on between the drive shaft and flange EDIT: Sorry didn't read the bit about it being a live axle ![;)](//storage.proboards.com/forum/images/smiley/wink.png) This is what I'm looking at making but it looks like il be fitting it on the gearbox output flange just need to work out the teeth ratio
