aaronb
Fezza nearly done
Hello all Can anyone advise where I can get the fuel pump push rod for my 1983 xr3i fuel pump. I have searched forums and scrap yards but I am struggling now. Any help would.be perfect or if.you have one I will buy it. Please help RR
THANK YOU
On an XR3i or do you mean XR3?
ring burton power tomorrow morning. sure they could help??
aaronb
Fezza nearly done
Yeah sorry my engine is a xr3i and I'm running carbs due to space in mk3 fez. I will try Burton. Thank you guys
I'd be tempted to get a Facet and an FPR TBH.
Depending on the carbs I'd even suggest an SU pump.
aaronb
Fezza nearly done
I was going to go that route but my aim is to get it up and running and mot and run in then I will pop her in garage next winter and forge pistons high lift can upgrade pump and looking and bike carbs. My little pocket rocket.
PS I got the push rod. Ford sell them for 28.42, Thanks for all the help chaps and chapesses
That is a result but also surprising.
A number of things for Mk3s are now NLA from Ford.
aaronb
Fezza nearly done
I'm.finding most things that are difficult are available. Second hand parts are difficult. IE complete hubs etc. I'm using eBay,burton and motomobil. To name a few. I have a few fezza now so if I can help ill try.
I was going to suggest cutting a piece of suitable diameter rod to the correct length if ford didn't sell them
It might be worth you putting the finis number on a reply, that will help people googling for a pushrod
Last Edit: Jan 9, 2018 20:46:52 GMT by fordperv
Jan 10, 2018 10:46:20 GMT
Tried motomobil, oldpartstore or newford parts?
Last Edit: Jan 10, 2018 10:47:09 GMT by grifter01
aaronb
Fezza nearly done
Jan 10, 2018 14:48:23 GMT
Motomobil stick the part. I got mine from Ford dealer parts. 28.42. I'll add a part number when I get it.
aaronb
Fezza nearly done
Jan 10, 2018 15:03:52 GMT
Ford parts 28.42 - part number 6098072 pre 85 xr3
aaronb
Fezza nearly done
Jan 16, 2018 16:51:07 GMT
This part fits. And work.
