This popped up on my facebook this morning.
262mph in a streetable nissan, who needs a Veyron/chiron ?
specs as follows
SPECIFICATIONS '91 BONNEVILLE
Base vehicle NISSAN FAIRLADY Z
Engine model VG30DETT
Bore / stroke89.0mm / 83.0mm
Total emission 3096cc
Compression ratio 8.3: 1
Maximum boost pressure 2.0kg/cm 2
Maximum output 1000ps
Maximum torque 90kgm
Component part
Camshaft JUN high lift cam shaft IN / EX 272 9.5mm
ValveNormal (processing)
Valve spring JUN original
Valve retainer JUN original
Piston JUN original
Con rod JUN I-beam connecting rods
Crankshaft Normal
Turbine BLITZ KKK K27 X2
West gate BLITZ TYPE RC X2
Boost controller BLITZ
Intercooler ARC TYPE III
INT manifold JUN GT-Surge tank (prototype specification)
EXH manifold JUN Exhaust manifold prototype specification
Muffler JUN prototype specification muffler
Radiator Mfg.JUN prototype specification
Oil cooler TRUST
Fuel controllerJ UN CPU
Injector JUN high-capacity main injector 890ccX6 Add 550cc X4
Fuel pump / tank BOSCH X2
Clutch OS Giken triple plate TS3B
Mission Original 5-speed cross
Final gear ratio2.4
LSD
TireGOOD YEAR / MICKY
Wheel SPEED STAR
Suspension JUN original
specs as follows
Component part
Piston JUN original
Crankshaft Normal
Oil cooler TRUST
Final gear ratio2.4
LSD
Wheel SPEED STAR
