1998 Mazda MX5 1.8 s (140bhp)
Factory fitted Torsen Limited Slip Diff (LSD)
Nardi Steering wheel
Electric Windows
MOT until June 2018
136k miles
Pioneer stereo (with aux in)
Bodywork has had the usual rust treated, the paintwork could be tidied around this but it is solid where it should be if not the tidiest example in the paint department!
Recently had a Powerflex Mani back exhaust with the original cat built in, lifetime warranty with this and a bit sportier sounding than standard.
Recently serviced including gearbox (diff) oil change, also had new radiator, plugs, HT leads and rear brake discs and pads (I also have a new set of front discs and pads to go with the car, they didn’t need changing yet but bought them as a set with the rears)
Had a new clutch fitted by previous owner but clutch release bearing wasn't changed so could do with being done. Handbrake needs adjusting, works as a parking brake but if you want to drift or autosolo it'll need the cable tightening.
Soft top has a tear, repairable with a patch see the last photo.
£1095
Based in Chichester, West Sussex
(NB. the grille in this photo is no longer on the car)
Electric Windows
MOT until June 2018
136k miles
£1095
