fad
Dec 11, 2017 13:20:51 GMT
Hello all!
I am looking for an unusual bolt size...
M12x1.25, 60mm-80mm long, case hardened, 10.9 for preference (though 8.8 at a push if needs be and there really is no other option). Cup point grub screw for preference, cap head for second, hex head if there's nothing else, must be threaded all the way down...
I cannot for the LIFE of me find something that fits!!!
I have tried:
Orbital Fasteners Hague Fasteners (they can do them for me for £145 the pair) Ebay TR Fastenings
...and a whole bunch of other places online.
Anyone got any thoughts?
Dec 11, 2017 13:29:43 GMT
ahh you need a screw not a bolt.
what is it for?
fad
Dec 11, 2017 13:35:07 GMT
ahh you need a screw not a bolt. what is it for? Yes it's a set screw I need, but I put "bolt" because most folk don't know the difference unless you explicitly point out a fully threaded shank vs part threaded. In any case, it is for an adjustable suspension setup on my Volksrod. Hague got back in touch and said they can tag my requirement of two bolts onto the back of an order going through for £100... / Must be very expensive to make!
Dec 11, 2017 14:02:24 GMT
fad
Dec 11, 2017 14:08:23 GMT
Run a tap down a case hardened bolt? What kind of taps do you have? LOL
That said it's an 8.8, might get away with that, but the tapped area will be exactly where the load will be much of the time, not good. Will put a pin in that one for future use...
Dec 11, 2017 14:11:26 GMT
ones that are now a bit blunt :lol:
got an image of the application? it seems that 50mm is the longest you will get a fine threaded bolt/screw without having to have a shank.
I do have a wheel stud actually that is M12x1.25 but obviously wont have a head on it.
Dec 11, 2017 14:13:12 GMT
Dec 11, 2017 14:16:15 GMT
alx
Club RR Member Number: 21
Dec 11, 2017 14:36:30 GMT
Last Edit: Dec 11, 2017 14:37:38 GMT by alx
fad
Dec 11, 2017 14:36:44 GMT
This, basically.
fad
Dec 11, 2017 14:55:49 GMT
Longest I found is 50mm cap heads in various grades. It may have to do.
Dec 11, 2017 15:01:08 GMT
ahh, have you checked that an 80mm fastener will still be touching the arm? I have a feeling it will miss it.
would be far simpler to weld the threaded post further around, unless you still need full adjustment range back to standard height.
fad
Dec 11, 2017 15:04:47 GMT
ahh, have you checked that an 80mm fastener will still be touching the arm? I have a feeling it will miss it. would be far simpler to weld the threaded post further around, unless you still need full adjustment range back to standard height. That's not mine, that's an example of one. Mine is a custom made job, about 40mm of the thread is taken by the threaded block. Mine pushes against a broader block but stays within a sensible angle so as not to snap the bolt (the load comes closer to the line of the bolt the more thread is wound through).
Dec 12, 2017 10:41:51 GMT
Last Edit: Dec 12, 2017 10:46:02 GMT by droopsnoot
fad
Dec 12, 2017 11:53:21 GMT
Trouble is the cap heads are bolts and have a max thread of 35mm. Tried Spalding before. I think I'm going to have to rethink and maybe redo the spring plates in an M12 coarse.
Dec 12, 2017 11:56:53 GMT
or move the threaded post closer?
Dec 12, 2017 12:05:48 GMT
Trouble is the cap heads are bolts and have a max thread of 35mm. You're quite correct, not sure how I didn't notice that as it's in big letters.
fad
Dec 12, 2017 13:44:15 GMT
or move the threaded post closer? Nah, can't do that, I MEANT it when I welded it!!
Dec 12, 2017 14:04:01 GMT
thease any good to you fad?
fad
Dec 12, 2017 14:38:53 GMT
Thanks, but 'fraid not buddy. Needs to be threaded all the way down.
