Hi all
Have had this sat about and it needs to go as I've no time to put it into something.
Its been removed from a Civic Type R Ep3.
It consists of complete Loom inc ECU
Drive Shafts complete
Engine with inlet and exhaust manifold
Gearbox still attached so Clutch and Flywheel inc
There maybe a few engine mounts to go with it too.
There's also a few other parts to go with it if you'd want to sell them on to make a few ££s back...
rear spoiler
One front Hub inc disc and Caliper
Rear Calipers with carriers
Steering wheel with Column
Exhaust back box
Bad points
Engine jumped its timing... I think they are known for it.
So previous fella began stripping it down.. He Only got to removing the pulleys and CamShafts.
The Head is still intact and most likely the majority of these engines such as the B series and H series.. The valves will not be damaged..
This would be ideal fit for a track/ custom car build..
Price is £400 ovno for everything..
Considering the 6 speed box is worth minimum £300.
The bottom block is worth a fair bit.
Ideally could be forged to run FI.
So grab yourself a bargain.
Parts are Near Leeds.
Can deliver at an extra cost.
Regards
Pm me for further info.
rear spoiler
Exhaust back box
Bad points
Regards
