Jul 30, 2019 10:04:37 GMT
I've just been catching up with your progress, the finish is amazing!
Have you stuck the seals on the doors yet of will this be done now they've been fitted to the shell?
Also Pete - where did you buy the tank seal from?
Jul 30, 2019 10:11:42 GMT
Jim Someone I know has a Mk1 and is in the owners club he ordered it for me along with a couple of other parts when he placed an order as you have to be a club member to order there parts . Once I have the car back if it turns out I cannot use it I will let you know, no I know you need one.
Jul 30, 2019 10:32:44 GMT
No worries Pete, I hadn't considered a seal as there wasn't one in my car when I took it apart which was odd but not surprising given the other stuff that had been done to it before I owned it!
Jul 30, 2019 11:50:11 GMT
Last Edit: Jul 30, 2019 11:51:29 GMT by Deleted
Jul 30, 2019 12:09:29 GMT
Thanks Chris, I'll bear that in mind but is it difficult to apply those seals when they're on the car? or have you fitted the doors to make delivery easier?
I'd like to fit the doors in 1 go rather than remove and reassemble to prevent damage but I don't have the seals and I'm tired of moving the doors, boot and bonnet all the time!
Jul 30, 2019 12:15:30 GMT
Thanks Chris, I'll bear that in mind but is it difficult to apply those seals when they're on the car? or have you fitted the doors to make delivery easier? I'd like to fit the doors in 1 go rather than remove and reassemble to prevent damage but I don't have the seals and I'm tired of moving the doors, boot and bonnet all the time! Jim - I'm in the same boat - I don't have a lot of room in the workshop - so I fit any loose panels to the bodyshell once they are painted - Its pretty straight forward with the doors fitted to fit the rubbers - Pete wont be taking the doors off to fit the rubbers on the Corsair
norm75
Jul 30, 2019 13:11:45 GMT
I didn't think you were that tall Chris I mean lie them flat then hang them on the hooks. Ah I see - but no the roof space is too tight and secondly I really don't like storing anything that is not essential in the workshop has it gathers dust - said dust then tends to make a bid for freedom but only when I have wet paint on a panel which it likes to land in - I think I have somewhere for the stands - I just need to go & purchase some sky hooks Do you mean sky hooks that you get from the shop you are sent to for left handed screwdrivers, tartan paint and long weights, or the actual skyhooks that are an actual thing nowadays.
Jul 30, 2019 15:05:48 GMT
I need some of that stuff, what brand are you using? Dynamat seems ridiculous yet using roofing products doesnt feel quite right! Link to supplier - they do a few different ones dependant upon where you are using it on the car - I used the standard 500 x 500mm bitumen sheet ones for the doors that are £6 each www.martrim.co.uk/car-trimming-supplies/heat-shield.phpThe bitumen stuff. Typically how much do you use? Thanks
Jul 30, 2019 18:47:48 GMT
The bitumen stuff. Typically how much do you use? Thanks 1 500 x 500mm per door - then you can always do the rear wings / floor pans if required
Last Edit: Jul 30, 2019 18:48:27 GMT by Deleted
Jul 30, 2019 19:27:13 GMT
Remaining loose panels clear coated Left for a few hours to go tack free Then on with this This is the original headlining And it's dead New headlining ordered by Pete from Aldridge Trimming whom until today I rated has one of the top vehicle trimmers in the country - I no longer do now The material is has per original - a cloth backed vinyl - so why the hell have they folded it up rather than supply it rolled - Utter Numpties This is going to create no end of additional work I gave the support hoops a quick clean up Ford had a colour coded system for the hoops Initial fit - dreadful I worked around it stretching has required then clamping Note the card protection to prevent the clamps digging into the headlining or paint Slightly less dreadful - idea being is to leave it under tension overnight then have another go at it tomorrow - the majority of the problem being the crease marks from where it was folded - this is just pure sloppy laziness on the part of supplier - had they supplied the headlining rolled it would have been far easier - To**ers Took a look at the rear roof pillar trims which are covered in the same material Metal panel with sponge scrim that the material is formed around Tell tale signs that the rear windscreen has been leaking then Surface rust removed and a few coats of etching primer applied - I will face with a sponge scrim tomorrow prior to recovering them in the fabric More tomorrow
Jul 30, 2019 19:31:08 GMT
I used like Chris, pieces of 500 x 500 for each door and did the floors, firewall and rear inner fenders. I used 2 or 2 layers on the floors to fill the ribs. Also did the boot floor I must have used about 4 square meter
Jul 30, 2019 20:26:02 GMT
time , gravity and an amount of stretching on the headlining chris , or add in a gentle application of steam?
presumably brains were in balls when healiner was produced/dispatched!!
Jul 30, 2019 21:15:29 GMT
The one for our minor was folded as well, even after being storred for 2 years the creases came out easily enough after leaving it laid out flat for a couple of days.
kenb
Jul 30, 2019 23:43:20 GMT
I had an Aldridge lining too. Same problem, folded flat, the stitching wasn't 100% even either, but by then I've got a bloke on site trying to fit it. He persevered but still had a crease which we couldn't get out, no matter how we stretched it due to the line of stitching being slightly out of position. As I'd already had a falling out with them over the door cards which weren't all that either, I really couldn't be bothered to go through all the aggro again. The only thing in their favour was the sun visors they did were spot on, clean plastic seam welded around the edges just like the originals. But their customer service is pretty dire for the prices they charge. Problem is for Corsair stuff they are or were until recently the only "go to" place. I see EKT are now selling headlinings, but I have no idea on the quality of those. In the past it was another company I wouldn't use, but gather they have a new manager at the helm. Pics of the door cards of the trim lifting as they arrived out of the packaging. Refused initially to sort it out until I pointed out I'd paid by credit card.
That is really bad when suppliers knowingly screw up, and continue to do so.
I am sure customers have pointed this out to them before.
I do not have a credit card, but this certainly makes a case for using one, in order to put pressure back on them.
I continue to just watch in awe team.
another good "threat" these days is social media...details of poor quality and service can be in front of massive amounts of potential lost customers with a few tappety-taps of keys and the click of a mouse!! don't bother with trading standards....they are a waste of time!!
Its appalling has to how many suppliers turn out poor quality parts or simply just cant be ar8ed to package it properly - I see & hear of it all the time - even some of the suppliers that did have a good reputation have gone down the pan and its very difficult to source good honest suppliers for the sub £50k classic / collectable market - rise above that figure and there is a host of marque specialist companies out there that provide excellent products but at eye watering specialist charges - that said there is also a bunch of shysters out there in the higher end of the market peddling their wares. Personally I only sell my services bar the odd rare Jowett trim part which we make in house (mainly interior trim) but I take a upmost pride in what we offer - where the hell has the pride in the job ethos gone with this country
avg
Jul 31, 2019 12:00:14 GMT
Pride in the job is still alive and well and living in a small village in Hampshire... and long may it do so.
Last Edit: Jul 31, 2019 12:21:03 GMT by Badwolf
Jul 31, 2019 12:12:00 GMT
most can't even spell pride now , let alone have any in a job!!
i don't particularly like my job but it pays the bills and i do it to the best of my abilities/patience on any given day. the younsters there just drag their butts around without caring either way. i WILL go johnny rambo one day at having to do my job and others!!
*sorry...off topic rant!!
