Jan 12, 2020 16:51:26 GMT
You must be The Toledo Centre of Excellence, and all the remaining Toledos have heard about you and want to come hang out at your house; "Please Sir, may i have a twin-cam upgrade?", or "I will gladly sacrifice my bits and pieces if it means my brothers can survive!" John
Drizz
Absolutely incredible work! An epic project!
MGF VVC 160 MG Midget Metro Turbo 200 BRM Range Rover Classic TD5 Discovery Premium 300TDi Defender 90 Rover 420 GSi Sport Turbo Discovery Extreme 300TDi Range Rover P38
shoey
Mar 14, 2020 14:48:49 GMT
shoey
Mar 29, 2020 15:37:33 GMT
O/S tail light repair don't know if anyone else as encounter their mig struggling to arc when using super strength magnets bought this 2hp 60l compressor local to me cheap unfortunately the motor had seen better days so back on ebay for this 4 pole motor,hoping its going to have the capacity for spraying,plan is to prime the car and depending how that goes I ll have a go at the top coat in an attempt to get all round the car bought these cheap dollies which started to buckle forcing the castors to tuck under when shifting the car around,so welded this web on to strengthen mopping up last little welding jobs also got the boot lid and drivers door shot blasted to get rid of the deep rust and gave them a coat of epoxy thanks for looking
Darkspeed
Club RR Member Number: 39
71 Triumph Toledo with BeamsDarkspeed
@darkspeed
Club Retro Rides Member 39
Mar 29, 2020 16:07:24 GMT
That's a yes on the magnets - and they do not have to be super strength either - I always try to keep them as far away from where I am welding as possible.
v8ian
Mar 29, 2020 17:23:55 GMT
Yep magnets do cause a problem, I think the magnet pulls the molten metal towards itself not allowing the metal to flow to the weld area
ndg
Mar 31, 2020 13:08:59 GMT
Yes on magnets here too. Even the cheap corner clamp magnets do it if I get too close. Seems to drag the arc towards the magnet when I've had it.
Mar 31, 2020 18:56:08 GMT
Only found this thread earlier today, amazing work.
Mar 31, 2020 19:41:19 GMT
Cant understand why people get old rusty Triumphs, modify them and try to drag them, kicking and screaming, into the modern world.
It's mental, just like the cars when their finished.
“It Doesn’t Feel Pity, Or Remorse, Or Fear, And It Absolutely Will Not Stop, Ever, Until You Are Dead!”
shoey
Apr 23, 2020 13:04:50 GMT
shoey
Apr 27, 2020 14:56:26 GMT
rear o/s wing and inner arch are toast drilling out the spot welds but where to split the rear wing?,if you buy nos from Rimmers you get the complete B pillar,window frame and the tail light panel I ve decided just to replace the skin,and make the join half way up the C pillar donor wing in decent nick,had to remove part of rear sill to gain access to spot welds finally separated a lot of the neighbours around here are furloughed and sunbathing so not trying to make to much noise but its difficult to split welds quietly home made weld splitters,12m allen key and an old mechanical saw blade,thanks for looking
Apr 27, 2020 19:27:28 GMT
Another fascinating looking project, is the red one going to be a standard resto or a fast road weapon?
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
Apr 27, 2020 19:27:58 GMT
Always a great thread to learn something and be impressed by.
Question: did the FWD versions of this body style also use a Herald-style ladder chassis, our were they full unibody?
Thanks, John
shoey
Apr 27, 2020 19:41:59 GMT
Another fascinating looking project, is the red one going to be a standard resto or a fast road weapon? Hi cavboy80 I'm looking at getting the body as best i can then a simple Vauxhall redtop conversion,it wont look to different from standard from the outside.
shoey
Apr 27, 2020 19:50:44 GMT
Always a great thread to learn something and be impressed by. Question: did the FWD versions of this body style also use a Herald-style ladder chassis, our were they full unibody? Thanks, John Hi John both were uni body, there are subtle differences between FWD and Toledos ,FWDs have independent rear suspension more like a Triumph 2000 than a Herald, were as Toledos are live axle,Toledos are more down market,thanks
trimtechniques
Porsche 928 4.7 ltrs of German grunt. Mazda MX-5 MK1 Dakar. VW T4 camper
Apr 27, 2020 21:13:48 GMT
Well I have just read your thread from the start. And I can only say WOW! I love Triumphs, and my biggest mistake in my car owning history is selling my Dolomite Sprint back in 1983. I am in awe of your skill and vision. I hope to see it in the flesh if I can get to the Dr gathering and maybe say hello.
Paul Y
Just found and read whilst on yet another conference call. Good work, really enjoying this. Please continue. P.
shoey
Jun 14, 2020 14:00:47 GMT
hi small update,I know it doesn't look like it but dozens of hours spent trying to get body something like for spraying,I'm a novice at prep/paint work Ive always paid someone to spray my cars but you don t get much for a £2500 job like the last car,you can get a lot of equipment for that,plus they always seem to put their own touches you've not asked for,ie stone chip in the engine bay,underseal half way up the sills so thought Id have a go ,if I make a balls of it its down to me. o/s also needs quite a lot of filler,knocked all the high spots down got the engine and box ready for pulling so I can prep and spray the bay,its a real doddle to work on with the wings and front off almost as good as a GT6,thanks for looking.
Jun 14, 2020 15:14:10 GMT
Paintwork is the most time consuming job, hours spent getting the surfaces the correct profile. I agree with you that nothing spoils a restoration more than a half arsed prep and paintjob. The times i've seen cars that have shonky looking front/ rear valances with bends and dings for example. Keep up the good work, nothing wrong with having a go. The satisfaction will be worth it.
shoey
Jun 15, 2020 18:04:23 GMT
Paintwork is the most time consuming job, hours spent getting the surfaces the correct profile. I agree with you that nothing spoils a restoration more than a half arsed prep and paintjob. The times i've seen cars that have shonky looking front/ rear valances with bends and dings for example. Keep up the good work, nothing wrong with having a go. The satisfaction will be worth it. Thanks cavboy80 couldn't agree more,hats off to people who do it for living. engine and box out heres my all singing overhead crane,piece of 2" box section and a ratchet lift tomorrow I ll remove the sub frame for powder coating and fit a 2 wheel dolly from the last build to keep it mobile,thanks for looking.
