Sept 17, 2017 12:36:03 GMT
Any of you chaps got any recomendations for one of these. My lads taken a chunk out of the lower bumper spoiler of his Corsa.
I've got the broken bit and I fancy a go at plastic welding it. Can't find anyone local who CBA and some folk quote silly figures even SMART repairers.
I'd rather spend the cash on some kit
Sept 17, 2017 12:46:11 GMT
soldering iron and a plastic loom tie ,is what i use
Sept 18, 2017 14:49:13 GMT
Soldering iron - use it to melt the bits together on the back side, try to pull the pieces over each other to stitch the bits together for strength.
Sept 18, 2017 22:48:57 GMT
I have one of these, they use ABS plastic rods: the3doodler.com/Not for intended purpose btw.
Last Edit: Sept 18, 2017 23:01:02 GMT by DavidB
Sept 22, 2017 15:11:21 GMT
Exactly what the chaps have already told you - soldering iron with a large tip - you can purchase plastic bumper welding ribbons on e bay very cheaply - avoid the fumes / use in a well ventilated area - tack into place initially or use a couple of alloy plates with self tappers to hold the piece insitu temporally whilst you tack it together - airline & blow gun help to cool / set the plastic has you move around the joint seam - it will not look pretty but that does not matter - then just sand back with a 80's disc on a DA / orbital sander and make good with filler - use a filler suitable for use with plastics though has these retain more flexibility than standard fillers.
