Pugly
Dec 12, 2020 13:07:48 GMT
Thanks for taking the time to reply, I appreciate it! Are you intending to topcoat yourself?
I painted a van with tractor enamel a few years ago which resulted in a decent finish (despite spraying outside!) but lacked the longevity I would like or expect if it were a 2K paint.
jonomisfit
Club RR Member Number: 49
Dec 12, 2020 13:30:16 GMT
For the underside, bay etc. Yes.
I'll be using cellulose as I can spray that with my same setup.
For the exterior. Undecided.
I'll probably epoxy prime the exterior, but I'm still not certain if I'll the top coat. I'm tempted to do in cellulose simply because I can then do any repairs to the paint at home. But if I go to a paint shop they will do a better job of it, and it may be tougher paint finish.
Previous cars I've painted with cellulose have survived well. I just had to leave them a good wile for the paint to fully cure.
Dec 12, 2020 18:55:31 GMT
I've found a decent quality cellulose over epoxy seems to last well, it's also so easy to touch in damage or dodgy areas of paint, as you say both the epoxy and cellulose need plenty of time to cure though especially this time of year.
mk2cossie
Club RR Member Number: 77
Dec 12, 2020 18:59:06 GMT
Any reason for a black interior? As that is surely going to soak all the heat up in use Or is it purely for lack of glare on the inside of the glass?
jonomisfit
Dec 12, 2020 19:31:09 GMT
Its for the very technical reason of.....
I like black :-)
But also I find black looks ok for quite a while on a rally interior.
My experience is light colour interiors get grimey looking pretty quickly and need a load of maintenance to keep looking fresh.
Black looks black even when a bit dusty.
Heat soak wise I can't see it making a difference. Most heat soak will come from the engine / exhaust.
Maybe it might do a bit more solar absorption but the whole outside will be black anyway and will be the dominant factor.
Last Edit: Dec 12, 2020 19:33:50 GMT by jonomisfit
jonomisfit
Dec 12, 2020 21:07:31 GMT
Today was a busy day, but didnt end up with much vissible. I bought a couple of heaters and put them on raising the temp in the workshop to help cure the paint. It worked, and after about 20 mins it had got uncomfortably warm with my normal overalls and jumper on. Not sure of the exact temp, but I think it was pushing 20deg. I left it all to bake for a few hours. The paint felt noticeably harder to the touch by the end of the day. I then spent the rest of the day seam sealing the underside. I used PU adeheasive / sealant put on with the calk gun and then flattened with a finger. engine bay key seams. P1040511 by jono_misfit, on Flickr P1040513 by jono_misfit, on Flickr I've purposely not sealed the bottom of the inner wings as I want any moisture to run out not get trapped. Inner wings P1040512 by jono_misfit, on Flickr The gaps are where there's weld beads sealing, or at the bottom faces where i've again left open to allow moisture out. It looks fairly heavy applications as it black on light, however its a very thin smear on all joints. and the underside P1040514 by jono_misfit, on Flickr P1040515 by jono_misfit, on Flickr P1040516 by jono_misfit, on Flickr P1040517 by jono_misfit, on Flickr P1040518 by jono_misfit, on Flickr It took a surprisingly long time to do. Still it should all have set ready for me to scotchbrite the primer next time and get some white on it all. Which is now likely to be after Christmas.
qwerty
Club RR Member Number: 52
Dec 14, 2020 22:21:37 GMT
Read this thread from start to finish over the last few days.
Excellent work, really informative as well. Still haven't got my head around all the wiring yet!
Any idea on exterior colour?
jonomisfit
Dec 15, 2020 18:23:41 GMT
Thanks.
Well. Here's hoping i got it right and it all works!
Outside will be satin black, with a level of rally stickering and possibly some subtle gloss black or colour highlights in strategic places.
qwerty
Dec 15, 2020 18:36:03 GMT
Read this thread from start to finish over the last few days. Excellent work, really informative as well. Still haven't got my head around all the wiring yet! Any idea on exterior colour? Sounds Mean looking! Tom
jonomisfit
Dec 26, 2020 20:31:35 GMT
After a few weeks on other things I was back on the escort today. ] I scuffed back the paint to key it for the top coat. P1040521 by jono_misfit, on Flickr P1040523 by jono_misfit, on Flickr P1040522 by jono_misfit, on Flickr then started masking up P1040524 by jono_misfit, on Flickr P1040525 by jono_misfit, on Flickr the luminous green tape really pops against the black. Hmm maybe I need to find a way to bring it into the design of the cars paint. then to prevent overspray making it into the car I used poly sheetig to close all appertures P1040526 by jono_misfit, on Flickr P1040527 by jono_misfit, on Flickr flipped it over to start painting, and closed in a gap where one of the rollcage members passes through a double skin that is left open. P1040528 by jono_misfit, on Flickr then cleaned it all down with an air dust and panel wipe, then on with the paint. P1040529 by jono_misfit, on Flickr P1040530 by jono_misfit, on Flickr P1040531 by jono_misfit, on Flickr P1040532 by jono_misfit, on Flickr P1040533 by jono_misfit, on Flickr I got the first coat on the engine bay, them promptly ran out of paint! I thought I had two cans of white, but it turns out i didnt. This scuppers my plans but I've ordered more, unfortunately it wont get here until at least the 4th. Doh. I may well have to start prep work on some of the other bits, like wings, doors, boot, and interior panels (foot rests, and tank cover). Plus a few other jobs.
Last Edit: Dec 26, 2020 20:32:50 GMT by jonomisfit
jonomisfit
Dec 30, 2020 15:12:47 GMT
good news, all my paint turned up today, and its intact! :-)
Bad news, its -2 degC in the workshop and it's below my enjoyment threshold. Plus it'll be hard to keep it warm enough for the paint.
Its due to warm up from friday onwards a bit, so will look to get some more paint on the car then.
jonomisfit
So as per last post, the paint arrived. lots of it P1040534 by jono_misfit, on Flickr I had a tidy round and found a new space for it. Then mixed up some paint and went rount with the spot repair gun getting to all the difficult to reach places. Then flipped the car over and applied a light first coat of paint to the underside, starting off round all the seams and hard to reach places, then a light dust over all the floor. P1040535 by jono_misfit, on Flickr P1040536 by jono_misfit, on Flickr then gave the bay a once over again P1040537 by jono_misfit, on Flickr P1040538 by jono_misfit, on Flickr P1040539 by jono_misfit, on Flickr P1040540 by jono_misfit, on Flickr P1040541 by jono_misfit, on Flickr P1040542 by jono_misfit, on Flickr I did much better at avoiding runs this time, the paint grips much better when wet to the existing paint coats that it does when wet to the epoxy. put another coat on P1040546 by jono_misfit, on Flickr P1040547 by jono_misfit, on Flickr P1040548 by jono_misfit, on Flickr P1040549 by jono_misfit, on Flickr P1040550 by jono_misfit, on Flickr P1040551 by jono_misfit, on Flickr its starting to get there, but i think will need another couple of coats
looks good and well deserved after so much work done to a high standard!
jonomisfit
Thanks.
Its slowly getting there!
Looking good, a better finish than they ever had underneath when new.
qwerty
Excellent work, it looks great.
Tom
jonomisfit
jonomisfit
Then gave the floor etc a clean,swapped out the filters on the extractor and on my face mask, then set to putting another couple of coats on. I used the touch up gun first to get to the difficult bits first, then onto the main gun to get some volume onto the rest. P1040560 by jono_misfit, on Flickr P1040561 by jono_misfit, on Flickr P1040562 by jono_misfit, on Flickr P1040563 by jono_misfit, on Flickr P1040564 by jono_misfit, on Flickr P1040565 by jono_misfit, on Flickr P1040566 by jono_misfit, on Flickr P1040567 by jono_misfit, on Flickr P1040568 by jono_misfit, on Flickr there are a couple of small really really awkward bits that need a bit extra on, but I just cant work out how to get them! once its all set i'll see what I can do with the spot repair gun to get into them. But i need the paint to have a fair chance to set first as otherwise i'll just chip it trying to get into them. I banged the heaters on and gave it a hour or so at temp to help set it all off well. Once this was done I pulled the covering plastic off. P1040569 by jono_misfit, on Flickr a couple of spots the masking had moved and bled through a bit of paint. P1040570 by jono_misfit, on Flickr P1040571 by jono_misfit, on Flickr but these should be fairly straight forward to sort. I then moved on to masking up the car ready to sand / paint the outside. P1040572 by jono_misfit, on Flickr P1040573 by jono_misfit, on Flickr P1040574 by jono_misfit, on Flickr P1040575 by jono_misfit, on Flickr I've takem a few extra days off, so tomrorow will be finish the masking off, then sanding down the body.
some time spent on that i like it, i need a kick up the backside to get mine sorted
looks fantastic, must be a huge mental milestone to get all the paint on.
