jonomisfit
Club RR Member Number: 49
Mar 29, 2020 17:27:39 GMT
tacked in the other side of the box P1030203 by jono_misfit, on Flickr then cut some steel for the sealing strip P1030204 by jono_misfit, on Flickr to go here P1030205 by jono_misfit, on Flickr marked up some lines P1030206 by jono_misfit, on Flickr because it will only have a fold down one side, unlike the rest of the box, I ran a step behind the lid nuts, then folded up everything P1030207 by jono_misfit, on Flickr started adjusting to shape / trimming P1030208 by jono_misfit, on Flickr it ends up with some weird and wonderful shapes due to the ..... used nature of the floor area. P1030209 by jono_misfit, on Flickr clamped in to position to ensure square and flat. P1030210 by jono_misfit, on Flickr P1030211 by jono_misfit, on Flickr and tacked in P1030212 by jono_misfit, on Flickr I may add a central reinforcing strip, just to stiffen it up a bit. P1030213 by jono_misfit, on Flickr then got some steel and some hammers out P1030214 by jono_misfit, on Flickr cut in half P1030215 by jono_misfit, on Flickr and welded in to the corners P1030216 by jono_misfit, on Flickr to finish them off P1030217 by jono_misfit, on Flickr tank in position P1030218 by jono_misfit, on Flickr P1030219 by jono_misfit, on Flickr i think i'll end up making a hose guide for the feed hose. to make sure it is suitably supported. P1030220 by jono_misfit, on Flickr Looks ok to me, next job will be on to the top.
jonomisfit
Mar 29, 2020 20:11:18 GMT
I don't think that the tank mount is going anywhere soon Superb fabrication work as always - I'm guessing you are on a 'working from home basis' - Chris
jonomisfit
Thanks.
It looks sturdy but total weight of its low. I'm conscious of not getting too much extra weight into the car.
I am working from home, however I'm still doing 40hrs of work work mixed with child care, so only really getting a day on the cars per week.
I'd prefer it was more.
ian911
Wow!That rear tank support piece was vert complexed,hats off to you mate, how did you form the dimples that match the original floor swages?
jonomisfit
Thanks.
A vice, a hammer, and some 25mm box section.
I opened the vice jaws about 30mm, positioned the part over them, then tapped the 25mm box down onto the panel into the gap at an angle. It gave a tapering swage runout.
With a bit of dressing once in position it fitted ok.
Theres also a dip mid floor thats wider, so I did similar then gave it a tickle with the stretcher to add a bit more depth, before dressing with the hammer.
jonomisfit
Box welded in P1030326 by jono_misfit, on Flickr P1030327 by jono_misfit, on Flickr and given a bit of orange prevention P1030328 by jono_misfit, on Flickr P1030329 by jono_misfit, on Flickr Sunday should be on to starting the top. I also tidied up the workshop a bit, and started looking at what tools I need for the CNC lathe. Boxford are so kind as to use a custom insert size (9mm) rather than the normal 7 or 11, so I need to buy new tooling. Boxford tips are £12 + vat each and they wont sell them to me as i'm not registered as a machine owner... Luckily the tips might be an odd size but the shanks are 10x10, so normal tooling can be used. On the plus side I've learned a bit about the ISO coding on tools and inserts, and cromwell / cutwell have what I need. the downside is a decent holder is about £50+vat, but tips are <£5 each.
jonomisfit
Bolted the fuel tank in P1030330 by jono_misfit, on Flickr P1030331 by jono_misfit, on Flickr then took some measurements and did a dodgy sketch P1030332 by jono_misfit, on Flickr cut some aluminium sheet and started marking out P1030333 by jono_misfit, on Flickr more marking out P1030334 by jono_misfit, on Flickr start trimming P1030335 by jono_misfit, on Flickr more trimming, and make some holes P1030336 by jono_misfit, on Flickr swage the hole edges over, these are for access to the filler neck, vent / return ports, and fuel sender. P1030337 by jono_misfit, on Flickr start the folds P1030338 by jono_misfit, on Flickr getting closer P1030339 by jono_misfit, on Flickr and in position P1030340 by jono_misfit, on Flickr P1030341 by jono_misfit, on Flickr its all worked out pretty well, other than the sloped rear edge, which I've folded 20mm too long, so will need to anneal the ali, straighten a bit, then re-fold. Which will be tricky but should be doable. I also might re-cut the filler hole slightly larger for a bit more clearance. once i'm happy with it it'll get tigged up.
jonomisfit
with much effort and swearing I managed to re-bend the flange. Sits ok, Just a bit of dressing to do when Its sociable to hammer again.
Can't you just hammer at a distance? Seems a bit obnoxious to go to a public space and hammer things...
jonomisfit
My neighbor to the rear is only about 3m from the garage back wall.
So I'm always cagey about doing noisy things after 7pm.
jonomisfit
I went out the back this evening for some aluminium tig practice. I managed to get some setting that worked, so had a go on the first couple of seams P1030342 by jono_misfit, on Flickr P1030343 by jono_misfit, on Flickr whilst it wont win any prizes, its definitely a big step forward in my ali welding.
I know it's meant to seal off from the cabin... But can you find some swage stickers or something, so it matches the rest of the car? On the subject of sealing, is aluminium an accepted sealing material? I would have thought it would have to be steel of a certain thickness to hold fire at bay for a while or something. (No actual idea what the requirements are. Could be ok to make it out of cardboard for all I know!)
jonomisfit
I was going to swage it, but due to the throat on the bead roller I couldn't get it to fit.
If you look at tracks cars etc, they don't even shield the tank and pumps. Rally cars there has to be a metallic bulkhead.
It's meant to keep fuel and fumes in, it says fire as well, but theres no withstand criteria so cant be for any appreciable duration.
Most ones I've seen are aluminium, including the ones provided by pro motorsport fuel cell providers.
jonomisfit
Apr 10, 2020 20:10:01 GMT
Drilled off the tank cover for the hold down bolts the side flanges are a bit tighter than I would have liked. P1030344 by jono_misfit, on Flickr P1030345 by jono_misfit, on Flickr P1030346 by jono_misfit, on Flickr I folded down the edges then made some infill pieces for the corners P1030347 by jono_misfit, on Flickr welded them in P1030348 by jono_misfit, on Flickr P1030349 by jono_misfit, on Flickr they still need cleaned back then marked up the fuel filler hole and enlarged P1030350 by jono_misfit, on Flickr on to the fuel sender access port P1030351 by jono_misfit, on Flickr piece of ali P1030352 by jono_misfit, on Flickr rounded the corners and marked out P1030353 by jono_misfit, on Flickr marked some more lines P1030354 by jono_misfit, on Flickr Which I then ran a bead round. P1030355 by jono_misfit, on Flickr The beading pulled it out of shape a bit so I gave it a go with the shrinker/stretcher to get it flat again. marked out again and folded some flanges P1030356 by jono_misfit, on Flickr fitted some riv nuts P1030357 by jono_misfit, on Flickr cover in place. P1030358 by jono_misfit, on Flickr the panels removable so I can get into the fuel sender connections without having the remove the whole tank cover. just in case. cut a stip of ali and formed round a handy former (a cutting die) P1030363 by jono_misfit, on Flickr ran a bead round it P1030364 by jono_misfit, on Flickr start tigging on P1030365 by jono_misfit, on Flickr (and take a break for a re-grind on the tungsten after I dipped it :-( ) welded in P1030366 by jono_misfit, on Flickr P1030367 by jono_misfit, on Flickr needs cleaned up. but gives a nice 95mm diam stub to clamp some aluminium ducting hose to (to protect the fuel filler hose) fitted the cover again, all sits nicely P1030368 by jono_misfit, on Flickr P1030369 by jono_misfit, on Flickr P1030370 by jono_misfit, on Flickr looks huge, but is lower and more central than the normal fuel tank location.I also think I went a bit big on the tank size, so I may end up trimming the tank down at a later date. next session will be looking at a cap for the vent / return points.
jonomisfit
Apr 12, 2020 20:01:34 GMT
Vent / return cap these two P1030373 by jono_misfit, on Flickr mark out some bits P1030374 by jono_misfit, on Flickr cut a piece of ali P1030375 by jono_misfit, on Flickr mark out P1030376 by jono_misfit, on Flickr cut some holes P1030377 by jono_misfit, on Flickr trim and fold P1030378 by jono_misfit, on Flickr clamp into position P1030379 by jono_misfit, on Flickr weld P1030380 by jono_misfit, on Flickr P1030381 by jono_misfit, on Flickr trim another piece of metal P1030382 by jono_misfit, on Flickr goes here P1030383 by jono_misfit, on Flickr welded on P1030384 by jono_misfit, on Flickr drill cover and fit riv-nuts P1030385 by jono_misfit, on Flickr cover bolts on like so P1030386 by jono_misfit, on Flickr tank cover back in situ P1030387 by jono_misfit, on Flickr P1030388 by jono_misfit, on Flickr I also bolted in a bearing to support the steering column through the bulkhead.The rubber bush thats standard is the source of many wayward steering on sierras and escorts. P1030389 by jono_misfit, on Flickr checked clearances with the seat in P1030390 by jono_misfit, on Flickr loads of room for a batter or extinguisher P1030391 by jono_misfit, on Flickr checked the pedal position again P1030392 by jono_misfit, on Flickr and swapped the seat to the passenger side P1030393 by jono_misfit, on Flickr you sit far too far back to be able to rest your feet on the bulkhead, so a foot rest is required.
jonomisfit
Apr 12, 2020 20:06:45 GMT
<cont> put a string line across the car so I can assess what the maximum height of a brace bar could be. P1030394 by jono_misfit, on Flickr take a load of dimensions, and sketch out a design. Mark out some ali P1030395 by jono_misfit, on Flickr some heel ribs P1030396 by jono_misfit, on Flickr fold P1030397 by jono_misfit, on Flickr cut out and fold two sides and tack in P1030398 by jono_misfit, on Flickr P1030399 by jono_misfit, on Flickr trial fit in car P1030400 by jono_misfit, on Flickr P1030401 by jono_misfit, on Flickr P1030402 by jono_misfit, on Flickr the top needs trimmed down still as its touching the dashboard, but feels like it should work nicely. The strange slightly folded bits at the side are so I can roll the edge over some 6mm ali rod I have. For me in the passenger seat it feels like the right position and angle to be a comfortable sit in the car. Once the trans tunnel to cage bar is in to fix it to it will be pretty rigid. Will maybe get another go on it later in the week.
Apr 13, 2020 13:31:04 GMT
Solid update!
Would the heel box not do with being a bit wider? I haven't been in a rally car, but I know I like to have my feet sort of wide if I'm in my mates car when he's giving it some beans around corners..
If there's room, that is.
Last Edit: Apr 13, 2020 13:32:57 GMT by varelse
jonomisfit
Apr 13, 2020 13:49:29 GMT
I'll take a pic when I'm out later.
For me it's a comfortable position with a bit of room to position feet. The bucket seat pretty much forces you legs to be straight out from the hips not splayed, so you're heels end up pretty close together.
I could probably make a bit wider at the top, but the bottom is tight for space where I need fuel lines to go past.
ian911
Apr 13, 2020 17:58:31 GMT
Your a clever curse word
