Jul 27, 2017 14:39:49 GMT
I'm sure the M5s MAF is a bit dodgy and contributing to my running issues. Normally Id just replace it but with prices varying from a grand to 1600 quid depending on where you look, you can understand my reluctance.
Are there any UK based companies that offer a testing/service facility?
93fxdl
Enter your message here...
Jul 27, 2017 17:14:54 GMT
Jul 27, 2017 19:44:20 GMT
atp electronics do the flap type, about 170 i think for a pug one, doubt a bmw one will be much different in price
Jul 27, 2017 20:40:12 GMT
the trouble is when someone cleans the maf with the wrong stuff! ie brake cleaner (which leaves impurities ) ive cleaned mafs with the proper electronic contact cleaner (maplins) and usually sorts them out unless its an internal fault
Jul 28, 2017 21:34:51 GMT
Thanks for the replies, Ill look into them.
Rolla I cleaned it with carb/intake cleaner but you raise a good point
The effectiveness of cleaning also depends on other things.
On the Range Rover P38, the early Lucas/GEMS MAF cleans quite happily, but the later Boch/THOR ones don't.
