Sammo
Club RR Member Number: 103
Jul 22, 2017 15:09:36 GMT
Afternoon I've owned my Mk2 XR2 race car for almost a year and so far all I've done is park it in my garage and stack piles of wheels around it! It requires both of the front wings, inner wings, battery tray, front panel and possibly both sills replacing. I have bought pattern repair panels and was full of good intentions on learning how to weld so I could do it myself. Unfortunately I'm just not getting the time to actually learn to weld, let alone weld it up once I've learnt! I would love to get the car up and running for a few track days next year and then aim to race it in 2019 but the way things are going it's not going to move from the garage unless I can find some kind person to wave a sparkly stick at it. Now the hard part to convince is that I can't really afford to pay much to get the welding done, but would hope to come to some sort of agreement. I'm based in Epsom, Surrey, KT19. If anyone fancies helping me out then get in touch. I know it's a big ask but if you don't ask and all that! Have a couple of pics of the car for good measure
Follow Me On Instagram - @parttimecartinkerer
Jul 22, 2017 17:16:03 GMT
Hi, A couple of ideas that.might improve your chances : Offer to do the striping and cutting out the problem areas for anyone who offers to do the welding (makes the welding easier) ask on the normally helpful mig-welding-uk forum (unlikely but you might get lucky) Barter? If you can't afford to pay a lot, can you trade some of your time or skills ? Hope you get sorted
Jul 23, 2017 22:27:47 GMT
I know a mobile welder based around the Sutton area, he normally welds Transits so he is used to rust. Not sure what his rates are though. PM me for his number if you are interested
fad
Jul 24, 2017 11:02:39 GMT
The trouble is, welding is one of those arts that many say they can do, but few can actually do well. It's dirty work, and when welding up rusty cars it's quite tough going sometimes. Without doing it yourself, you are going to struggle getting it done cheap to a good standard I'm afraid. Speaking for myself, if someone I was mates with locally asked me to throw a day at it for them I would, so long as they helped out and paid for the parts and consumables, but I would expect a favour back from them at some point. But if they asked me to do a whole car the answer would almost certainly be "Sorry mate"... Your biggest issue is the unseen. You have no idea how bad it is, or where the rot goes. From personal experience it is so often an iceberg thing, you only see the tip. Typically cars rot from the inside out, and that is the worst kind of rot. The way, the only way, you are going to get it done at a reasonable rate to a reasonable standard, is to strip the car right down, get rid of everything so you have a bare shell (I would recommend this before doing any sort of resto work anyway). Then, you want to (as suggested already) put to it with the grinder, and cut out every single shred of rot you can find. At this point I would then say "Go get it shot blasted" but no one ever does because that then means paint etc (which, ironically, is what welding usually means too!). Then I would get someone to come and cast an eye over it. I would feel WAY better laying seams down on a car that has already had the rot carefully cut out and has the correct panels ready to go, with someone there to do the clean, prep and grinding (the dirty work). Doing that will also give you more insight to how many hours go into welding up cars, and what a big ask it is for someone to do it cheaps / free.
ChrisT
Club RR Member Number: 225
Jul 24, 2017 18:32:48 GMT
^^^^^Wise words. It definately needs stripping down to see how much rot there is. I had an XR2 several years ago that failed an mot on 'a bit of rust' took the body kit off to find the floorpan barely attached to the outer skin the length of the car both sides.
fad
Indeed. You don't want someone to do what is essentially a patch job only to find it rots out again in a couple of years. I'm also careful about what favours I do for people too. I wouldn't fancy a repeat of the time I fixed someone's wiring when they broke down (snagged and melted live feed to coil, so took a live feed from the electric fuel pump to get them home) and explicitly warned them they urgently needed a rewire asap and it was in dangerous condition... only to find a few months later they were on a forum blaming me for "bodging" their ignition circuit which "caused" an electrical fire in their dashboard. Nowt to do with the 40 year old wiring, corroded earths, rats nest of under rated cables, burnt insulation, unfused switchgear, twist & tape electrical connections, aftermarket unfused fag lighters running heated seat pads and usb ports, and fuses replaced with bits of single strand copper mains cable then..? Grrr...
Jul 25, 2017 10:23:09 GMT
A good start would be for you to remove the bumpers and all the XR2 plastics. They will need to come off anyway to get work done, and it will let you (or your welder) have a good look at what needs repairing and what is ok. If the front end and sills need work, I'd also be checking the rear arches carefully.
Check the condition of the floorpans / sills inside the car, loosen carpets (if fitted).
I've heard a few times that bodykits look good, but you don't know what the condition of the car is under them until you start stripping bits off. It shouldn't be too dificult to find someone to check it for you once they can see the bits of the car that are hidden now.
Jul 25, 2017 12:32:22 GMT
thing of rust mulitply it by 3 times as much as you think, sexual favors will help lol , liken the car i replaced every panel including full floor s
