Jul 19, 2017 22:05:39 GMT
For the past two years since lowering my bus every time I've pulled onto my drive my side skirts have scraped on the edging block between pavement and the drive. The pavement slopes up and the drive slopes down so the edging block is at the peak, like so ... Since I fitted my sub and enclosure on Saturday, which has added considerable weight and dropped the front a few mm it no longer scrapes. I would have thought it would scrape more if anything or does the fact that the front is now lower and the overall ground clearance is more of a straight line, potentially positive rake make it more suited to clearing the peaked ground? Just curious really, thanks in advance.
Did you change tyre and wheel size when you got your new wheels? apart from the wheels being 0.5" wider no change - and it still scraped after the wheel change - only stopped this week since the sub has gone in.
Then I can only imagine it has added enough weight to unload (?) your rear axle. Not as much as in the following pic, but mildly?! And in the other direction of course. So if you ever should feel like missing that scraping, add some serious clarion woofer! 32" btw.That sub reminds me of the start of back to the future lol.
rude
1986 Haunted BMW E24 635CSi 1999 Povo spec BMW E36 1.8i Touring Work Hack 2001 Petrol annihilating Discovery V8 2000 Jaguar S Type 3.0 V6 ~NEW~
welshpug
new tyres with more tread?
Jul 20, 2017 10:21:23 GMT
Could it be that you just can't hear it over the sub?
Last Edit: Jul 20, 2017 10:21:46 GMT by droopsnoot
Jul 20, 2017 10:27:22 GMT
You've ground enough of a channel out to prevent catching?
Jul 20, 2017 11:08:45 GMT
new tyres with more tread? Nope
Jul 20, 2017 11:09:11 GMT
Could it be that you just can't hear it over the sub? Nothing is wired up yet.
Jul 20, 2017 11:11:42 GMT
You've ground enough of a channel out to prevent catching? Coincidence that it's happened at the same time as adding the sub?
Curtis
Jul 20, 2017 12:03:25 GMT
Then I can only imagine it has added enough weight to unload (?) your rear axle. Not as much as in the following pic, but mildly?! And in the other direction of course. It would only have this effect if the centre of mass was beyond the axle, as it'll act like a lever. In the above example, the load is behind the axle, making the rear axle the pivot, lifting the front of the car. With the woofer in the middle of the Elgrand, the weight will compress both ends, one more than the other depending on which its nearer to/has the lower spring rate
Driving: Shitbox Honda S-MX
rude
Jul 20, 2017 12:28:53 GMT
Have you considered that maybe YOU were lighter?I know that by looking at some of my non-flushables in the past that there was at least a few pound down there...
Curtis
Jul 20, 2017 12:41:47 GMT
I could certainly see where your thinking was. fr€$h&m1nt¥, if you can get a side photo of the moment it would normally scrape from the side we might be able to see how the van is sitting relative and get a better idea.
Jul 20, 2017 16:50:36 GMT
Scraping point used to be the skirt around where it's over the peak in this photo...
rude
Jul 20, 2017 18:50:41 GMT
Have you had a lot of rain recently?
steveg
Jul 20, 2017 19:03:19 GMT
Is the sub over to the left of the van and compensates for the weight of the driver or even tilts the van over to the left more ?
Jul 20, 2017 20:56:56 GMT
Have you had a lot of rain recently? Only last night but nothing more than previously
Jul 20, 2017 21:01:22 GMT
Is the sub over to the left of the van and compensates for the weight of the driver or even tilts the van over to the left more ? It's central from left to right but just behind the front seats so about 2/3rds to front. So with it being more left than me that could be the answer.
rude
Jul 20, 2017 21:14:56 GMT
Have any trees been removed or.... I think I'm looking too much into this...
Did it always scrape or just with all the three (well, two and a half) of you on board? Always scraped with just me on board, getting back from work and going to work every day - the only place it's ever scraped - apart from the exhaust silence on some speed bumps. It had been so annoying I'd considered air just for that slight moment each day, of course the lack of scrape now means I can go lower at the front on the coilovers until it scrapes again.
