Unfinished Project.
few dents and scratches
rust at bottom of bonnet and some surface rust forming around the front and rear screens.
Needs an MOT.
Has most of the interior stripped out but have it all to go back in.
Gearstick is threaded and has been modified for shorter shift.
75mm Lowering springs and 3" blocks
Landy 110 rear shocks
Welded diff
Needs handbrake sorting as doesn't work at all, probably needs a good service.
Needs welding underneath, has two wholes near the diff mounts, otherwise clean underneath.
Will be sold on standard steels.
Also have these wheels and 1.7 and F7R engines available separately.
395 ono
Needs an MOT.
Welded diff
395 ono
