Here for sale is my 1995 Golf Cabby.
I brought this last October off ebay from a guy near Nantwich. The pictures looked great, and bid on the car and won.
It was dark when I collected it, but the next day when I saw it in the light, OMG.
It was disgusting and filthy and it needed a lot of work. Disgusted with what I'd bought I covered it and waited for winter to be over and then started on it. This is what I did to get it into a resonable state.
New 12 Months MOT.
Milage 89945.
Lots of paperwork for work done and it had a new mohair roof 3 or 4 years back.
Will add pics of this paperwork soon.
There are links to my google drive which show all photos from start to finish
The interior has been took out and cleaned.
All interior front boot to dash has been cleaned.
Faulty Immobilizer removed.
The gear linkage was all worn , so replaced the lot. Gears work great now.
Rewired stereo and 12 cd changer properly.
The circuit board on the binnicle was shot so replaced binnicle. Still have old one to check milage.
Replaced rear window regulator.
Front & Rear bumpers taken off and body cleaned and sprayed with wax to stop any more water damage.
Drivers door earth wire rewired properly from a botch job.
Speaker covers were rusty so resprayed black satin.
Airbag system repaired and reset, so all works great now.
Front O/S light had water and green algae so took aprt and cleaned.
All body work and panels cut back by hand.
Cam Belt Changed and milage recorded.
Cooling system flushed and replaced with Pink Antifreeze, good for 5 years.
Rocker cover gasket changed.
New Battery.
Battery pan taken out because of rust and painted and replaced.
O/S inner drive shaft gaiter replaced.
N/S & O/S Tie Rod Ends replaced
All alloy wheels cleaned, but really could do with refurbishing.
All brake drums and claipers have been cleaned and painted red.
O/S & N/S brake disks and pads replaced.
2 X front to rear brake pipes replaced.
All brake fluid replaced and bled.
Engine metal air pipe cleaned out as it was blocked. Cleaned & Painted red.
Replaced steering fluid.
Replaced washer pipe.
Replaced both scuttles.
New wiper blades.
Repaired interior courtesy lights. One in front one in boot.
VW Valve Caps.
New downpipe from manifold.
Exhaust repaired for MOT.
Both sills have had old underseal removed rust cleaned away for MOT and re-undersealed after MOT.
O/S Door hinge repaied and lifted.
Soft top cleaned with Auto Glym soft top protector and cleaner.
Also took off N/S wing and repaired bad rust at bootm of wing, really could do with a new wing but had to repair for MOT.
New Number plates front and back.
I hadn't planned on this project being this bad, but there you are a lot of work. There are a few rust blemishes on the car but nothing too serious. I'm not a good body worker.
If I remember anything else I'll add it later.
OPEN TO OFFERS
Golf work photos, Google drive link.
New 12 Months MOT.
Milage 89945.
New Battery.
New wiper blades.
VW Valve Caps.
OPEN TO OFFERS
