Purchased this from one of my clients with the full intention of doing it and then selling on - due to my workshop diary now running into next year there is no way that I am going to get round to it anytime soon and I now need the space
1988 Mini Mayfair Auto
Low warranted mileage of 40,000
Matching numbers
Lots of extras - alloy wheels, veneer dash, race style filler cap, bonnet stripes etc
It failed it's test 2 years ago and has barely moved since, it starts, stops, drives selects all the gears etc - points of failure were:
NS windscreen washer jet - not working
NS sidelight - not working
OS headlamp - alignment too low
OS Foglamp - not working
Horn - not working
Rear number plate lamp - not working
Front subframe mounting (front panel) - corrosion
NSR subframe mounting (sill) corroded
NSF CV joint gaiter split
plus some advisories
What it really needs is:
New complete front panel
NS & OS sills
Rear valance
Both doors
Plus minor bits sorting for the test
The floor pans are fine has are the front wings bar some minor surface rust, both doors are heavily corroded but there is a decent NS one supplied with the car - the car is very largely on its original paint which is flat but it polishes up well, there is no sign of previous accident damage or repair of - it is a pretty straight & original car - it has a few age related marks and a few shallow dents to the roof that have not broken the paint. The interior is ok but would probably respond well to good shampooing of the upholstery. the engine bay is clean has is the underside of the engine & gearbox, tyres - tread depth is approx 2mm fronts & 3mm rears - it has a steel rim spare with a very good tyre on it, jack & wheelbrace - it has just had a new premium quality battery fitted to it
It comes with a wealth of invoices for previous work, quite a comprehensive history of MOT's that warrant the low mileage, along with the original owners manual
Pics below - It's for sale at what it owes me £950 firm or if you are someone that likes to haggle it's £1250 ONO but try find another that is this original and low mileage at this money - will make a great little car once done
I am based at a mid point between Reading / Newbury / Basingstoke - easy access from either the M3 J6 /7 or M4 J11/ 12
I have a tame chap who does my vehicle transport at sensible money if you need it delivered
Matching numbers
Horn - not working
NS & OS sills
Rear valance
Both doors
