hi all.
just fitting a carb conversion to my w115. as it was meant for a LHD car, the new carb fouls the master cylinder reservoir.
I need to lift the reservoir up away from the master cylinder like a remote mount - 50-60mm would do it. the reservoir usually presses into the master cylinder - couple of pics below to show the fittings.
question is - what would the fitting be called/where would I get it...that fits into the existing seals in the master cylinder so I can raise it up a bit?
many thanks!
many thanks!
