Hi Everyone
Was wondering if anyone had any advise for adjusting the K-Jetronic injection system in a 230e Mercedes W123. It is running really quite rich and has a nasty flat spot (then I am used to a fairly tuned 530d) most of the time.
Cheers
djefk
Firstly, I would give the car a thorough service, starting with a compression check and checking all settings such as valve clearances etc. Only then would I start looking at fuelling settings - plus if you don't have access to a gas analyser then I would take it a knowledgable friendly garage that does, you'll never get it spot on without one.
Let us know how you get on.
mylittletony
Club RR Member Number: 84
Check ALL the vacuum hoses around the inlet. I'd put money on a cracked or perished hose
Cheers Guys, I am away at work for another 2 weeks but will scope it out when I get back. I have already done a compression check and all cylinders seem good and very little difference across all 4. The car runs sweet as a nut without any other issues apart from being overly rich, idle is maybe a bit low as it wants to cut out when its cold, its fine when warm though, just a bit rich smelling.
Oil/filters etc are all good and new. plugs were not too bad.
I have access to a gas meter it reads CO in PPM rather than %vol though.
I Will check the vac hoses first, as I noticed another couple of hoses were a bit perished looking.
jpr1977
Club RR Member Number: 18
Jun 14, 2017 15:27:12 GMT
If you pm me your e-mail address i have a couple of K-Jet fault finding/service guides that may be helpful.
Jun 17, 2017 20:05:05 GMT
Also check the warm-up or cold-run regulator (google should deliver a how-to). This enrichens the mixture for cold start and during warm up. If it's broken, it's enriching the mixture all the time... If this checks out solid, the K-Jetronic can be adjusted, it's only the KE-Jetronic where you should not touch the CO-screw... But check the whole system first, especially the warm-up regulator.
Jun 17, 2017 20:46:10 GMT
Many thanks gents. As soon as I get off this floating rust bucket I will check these out
