Volkswagen Transporter T4 2.5 TDi 102hp 1200kg
Well looked after VW T4 camper/Day van. Starts on the button and drives on point, good on fuel and great on motorway runs. I bought this T4 a few months back in hope to take family on trips but due to lack of work i am now forced to sell. I have changed the:
- Disc brakes, brake pads and brake fluid with new all round
- Alloys + tyres all round
- New battery up front + re-furbished alternator
- New fuel filter with adative to give injectors a clear up.
Cambelt was changed at 120k, engine oil recently changed along with filter. Van does smoke on start up but i believe the diesel pump needs resetting which i will try and do before end of auction. Sadly this van is recorded as a Cat C, damage was to the rear barn door. The door has been replaced with a suitable replacement and painted to match the vehicle. There is no other damage to the van.
This is a genuine low mileage 2.5 TDi, great to just get in and have a great weekend away by the sea side. Below is details of what this van has:
Interior:
Driver and passengers captains seats, both have swivel base installed. Drivers base has safe installed but a new lock is required
Rock and roll bed with freshly made foam seats, covers and matching curtains. Seat belts for the rear are provided but not installed.
Cooker + cabinet in working condition, uses propex which is also included with the van.
Table top + pole makes a suitable table for eating/working.
Heat Source HS1800
800w Power Inverter to 240w single plug + 2x 2.1amp USB charging points
2x Lesuire batteries + rear 12v power socket
Front and rear independent spot lights, middle communal tube lighting. Twin sunroof, front and back. T5 floor seating rails (if you decided this wasnt for you, more seats can be installed)
Exterior:
17" King alloys from Germany (rare) max weight on each is 1300kg
Rear springs are a bit corroded but they are green 40mm drops
Front/Rear - Discs + pads new, Tyres have plenty of life. Brake fluid drained and re-filled.
All arches were sanded back to metal, stone chipped and complete van painted again from arches down. 3M Green Yellow Blue used to bring the top half of paint back to life. Locked in with Simoniz original wax
Roof bars with bike rack will go with van, right rear barn door re-painted due to rust and damage.
Pictures can be found in this folder: s87.photobucket.com/user/v1xz/library/VW%20T4
Any question please ring 07718991952
Interior:
Heat Source HS1800
Exterior:
