I have slowly been putting a kit together to put the 3 VAG auxiliary gauges into my early 80's audi as it is a povo spec and does not even have a coolant temp in the dash.
Got the gauges. got the sensors. Think I have the wiring sorted (bar which live feeds to take from the fusebox). I now need to find an adaptor to put 2 sensors into 1 hole. A bit like this:
Looking for M10 x 1 fine pitch on all the fittings. Luckily the sendors are all VAG so no nasty tapered threads.
Have a pic for my penance and hopefully your enjoyment
