May 13, 2017 17:02:07 GMT
Hi all, looking for some seats for a ginetta g26, as expected there has been some sort of leak while standing and it has ruined one of the front seats. Looking to get a decent set of front and rear seats from a different car as there is currently a mismatch between front and back. So far I know the required front seats are 520mm wide and the runners are 400mm. Are there any other seats from another car that would fit? prefereably nice seats that won't cost a fortune (as g26's are not an expensive car) thanks ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Dez
Club RR Member Number: 34
May 13, 2017 22:09:02 GMT
Mx5 seats are popular with kit car builders as they're reasonably 'sporty' but no overly expensive.
And yes they do tilt.
mx5 seats.....interesting. Ebay is flooded with them and I am sure the local scrappers will probably have some in too....
Rob M
Club RR Member Number: 41
May 14, 2017 11:00:33 GMT
I recently picked up a full set of leather, front and rear, seats from an 06 plate Hyundai Coupe for the grand sum of £40. I will be fitting them into my Firebird at some stage. You will be lucky to find a single MX5 seat for £40. Basically, look around, be patient and, if at all possible, look to fit your existing runners to the donor seats. A great many more modern seats have runners that weigh a ton with kick ups and all sorts of things that make fitting them to other car floorpans a real headache. Ive stripped one of the Coupe seats of its runners and have still retained the tilt mechanism. I will be making up brackets to fit the Pontiac runners to them and, as a bonus ( after having had a good stare at the sellers pics and online pics before I bought them ) the rear seats look like they are doable in terms of replacing the Pontiac rears without too much grief. Good luck!
Last Edit: May 14, 2017 11:01:30 GMT by Rob M
May 14, 2017 11:37:58 GMT
Last Edit: May 14, 2017 11:39:24 GMT by cobblers
May 15, 2017 12:25:29 GMT
My g26 had mondeo mk1 si seats in it but never felt like they fitted right so it now has a set of ford cougar seats (I already had them) and they work nicely. And have a built in tilt mechanism.
