Apr 21, 2017 20:19:15 GMT
Evening all. I have recently resprayed the metal bumpers on my MK2 Fiesta myself and I was looking for a bit of advice. So, it isn't going to be of a super duper quality I know (Halfords rattle cans, yup) but I was wondering is it better to flatten the paint with 1200 grit and remove the shine or just simply lacquer over what has been done already? There are bits where it isn't full of shine and certain parts have slight over spray, due to the angle I had to do it, hence why I thought I'd ask. It is instructed on the back to go with the latter, however I want to see what others reckon. Cheers
F503 FRM - MK2 Ford Fiesta - (Mo Filla, No Thrilla)
T527 LCJ - S2 Peugeot 106 - (Donor car for an AX GTI - scrapped) CA57 GWP - MK6 Fiesta Zetec S - (Daily derv go-kart)
Apr 21, 2017 20:25:53 GMT
Flatten it off to a finish you're happy with, add a final coat of colour then lacquer while the colour is still tacky, it will adhere better.
Apr 21, 2017 20:34:30 GMT
Flatten it off to a finish you're happy with, add a final coat of colour then lacquer while the colour is still tacky, it will adhere better. Cheers, mate. They will have had time to harden tomorrow, so I'll give this a go
Apr 21, 2017 20:35:19 GMT
I did that exact process with some bike plastics a few years back in my shed, they still look fine to this day.
Apr 21, 2017 20:40:43 GMT
I did that exact process with some bike plastics a few years back in my shed, they still look fine to this day. I have done a few jobs myself (wheel refurbs, plastic bumpers and a spoiler, as well as plastic trims). But this time I really wanted to get it pukka.
Apr 24, 2017 12:08:18 GMT
Is the top coat a pearl/speckle (almost metallic) finish, or block colour? If it's solid you can also flatten the lacquer with 2k and then polish fully for the final finish. If it's a metallic looking finish, don't flatten the lacquer, it will destroy then metallic look. Just go straight to polish. (Recently flattened the lacquer on my metallic green Mazda and it killed the shiny fleck look).
1979 Mk1 Passat Estate 1.6 LS 1996 Mk3.5 Fiesta 1.3 Classic 1997 Mk1 MX5 1.8i 2005 Mazda 3 TS
May 11, 2017 12:40:03 GMT
Is the top coat a pearl/speckle (almost metallic) finish, or block colour? If it's solid you can also flatten the lacquer with 2k and then polish fully for the final finish. If it's a metallic looking finish, don't flatten the lacquer, it will destroy then metallic look. Just go straight to polish. (Recently flattened the lacquer on my metallic green Mazda and it killed the shiny fleck look). It's just a Gloss Black, so a block colour. It came up perfect with the last method posted, just could do with a bit of polishing to really bring them up.
So the process worked OK. Good news. I find it easier to get a level coat of lacquer down when the paint is tacky as the solvents in the lacquer soften the paint a bit too.
